Dr. Zigzagus Posted February 2, 2022 Posted February 2, 2022 Aida64 Extreme v6.60.590. Motherboard Gigabyte Z590 D. BIOS v.F7a dated 24 January 2022. AIDA64 shows the problem that doesn't exist : "System BIOS is more than 2 years old. Update it if necessary." BIOS is less than 2 weeks old. Why it shows such a ridiculous advice? Quote
Fiery Posted February 15, 2022 Posted February 15, 2022 On 2/2/2022 at 7:15 PM, Dr. Zigzagus said: Aida64 Extreme v6.60.590. Motherboard Gigabyte Z590 D. BIOS v.F7a dated 24 January 2022. AIDA64 shows the problem that doesn't exist : "System BIOS is more than 2 years old. Update it if necessary." BIOS is less than 2 weeks old. Why it shows such a ridiculous advice? We've fixed the issue in the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Quote
Dr. Zigzagus Posted February 26, 2022 Author Posted February 26, 2022 Hi Fiery! Thanks for reply. I had downloaded the new beta from the provided source and that advice wasn't shown. It works. But I found a new bug in this BIOS section of AIDA64. Video BIOS info section shows value Unknown, but in GPU section it shows correct Video BIOS date, see screenshots. The Aida64 Extreme v6.60.590 has the same problem. Quote
