Hi all
i am new to this and I am really interested in using my old mobile which is approx 7” screen
https://www.gsmarena.com/xiaomi_mi_max_3-8963.php
spec above ^
would this work with Aida64, I would be looking to get a case mount or similar for this device and want to display my pc sensors on it
i have seen people do it with Samsung s5, so just seeing if it is feasible with this mobile, save me going out and buying a panel
thanks
11 hours ago, Techmob said:
Hi all
spec above ^
thanks
Yes, it would work with either RemoteSensor or Odospace.
Thanks, I got it working with odospace but couldn’t get full screen to work, even though I changed the resolution in Aida64 and set odospace to full screen.
I’ll post in the creators thread
thanks
