MrPix Posted February 5, 2022 Posted February 5, 2022 Hi I just installed some more fans on the only available headers on the above mobo. I have updated to the latest Beta 6.60.5918 on AIDA Extreme and the following are not showing up: CHA_FAN5 CHA_FAN1P Everything else seems fine and dandy. Could you please add these sensors? Quote
Fiery Posted February 15, 2022 Posted February 15, 2022 On 2/5/2022 at 8:43 PM, MrPix said: Hi I just installed some more fans on the only available headers on the above mobo. I have updated to the latest Beta 6.60.5918 on AIDA Extreme and the following are not showing up: CHA_FAN5 CHA_FAN1P Everything else seems fine and dandy. Could you please add these sensors? Make sure to upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. Quote
tonmoy Posted February 15, 2022 Posted February 15, 2022 "This is very rare that you can easily fix it"=You thought it? No. You can do it yourself just follow the above one's method. Nut I did not fall such problem as I am using this one= https://productz.com/en/trust-ventu-go-portable-cooling-fan/p/ZV4Lm Quote
