Öld Ðad Posted May 3, 2022 Posted May 3, 2022 Is anyone else having an issue with not being able to find the gpu temp on a 3090. Ive been using my sensor panel for abit now and have had no issues until i installed my new 3090. Everything else is working for the gpu such as the utilization and all of that but the temp doesnt and I cant find it in the program. I have a evga FTW3 rtx 3090 if that helps Quote
Drumbic Posted May 5, 2022 Posted May 5, 2022 On 5/3/2022 at 3:59 PM, Öld Ðad said: Is anyone else having an issue with not being able to find the gpu temp on a 3090. Ive been using my sensor panel for abit now and have had no issues until i installed my new 3090. Everything else is working for the gpu such as the utilization and all of that but the temp doesnt and I cant find it in the program. I have a evga FTW3 rtx 3090 if that helps I was having a similar issue with my 3080... Make sure you have the most up to date Aida64 release and then Uninstall and reinstall it. (Make sure you save your sensor panels before deleting). Once I reinstalled, EVERYTHING worked. Quote
Öld Ðad Posted May 7, 2022 Author Posted May 7, 2022 So i have to uninstall aida64 then reinstall it? Quote
Drumbic Posted May 7, 2022 Posted May 7, 2022 6 hours ago, Öld Ðad said: So i have to uninstall aida64 then reinstall it? For me and my 3080, when I couldn't see much of the GPU, it worked uninstalling and reinstalling Aida. Quote
Öld Ðad Posted May 16, 2022 Author Posted May 16, 2022 I tried uninstalling aida64 and reinstalling it but still nothing. i even tried a diff panel so im not sure why the temp sensor isnt in there. i wouldnt think its because its such a new gpu would it? Quote
Öld Ðad Posted June 6, 2022 Author Posted June 6, 2022 Ok I figured out the fix for this issue. If you cant find the temp sensor for the gpu look for the GPU Diode. It will be in the same section as the rest of the gpu temps are, click it and your good to go. I double checked with MSI Afterburner to make sure the temps matched and I watched it for an hour just to make sure the fluctuations were the same so now everything is working great... Quote
catch22 Posted November 26, 2023 Posted November 26, 2023 I got this beautiful template for Aida64 forum. Now I am trying to get my GPU 3080 temp on the display. I am using my on board graphics to run the 10' monitor and my main monitor is wired to 3080 GPU. But Aida64 is using the temp of my onboard graphics and not my GPU temp. How do I change this temp to my main graphic card. It will be something stupid I know but I am new to this so I hope someone can help. Quote
