sezers Posted September 19, 2012 Posted September 19, 2012 hi everyone i'm english bad, my cpu AMD Phenom II X6 1090T test in photoworxx result everytime and every cpu clock def 3.2 Ghz 1.250v - 4.0ghz 1.450v and 4.2ghz 1.525v result 16*** point test list 6x Phenom II X6 1055T 2800 MHz 24462 point system config Gigabyte GA-MA785GM-US2H AMD Phenom II X6 1090T kingston 2x2 gb ddr2 800 cl5-5-5-18 samsung 1tb hd103SJ sata2 point of view 550w peak 650w PSU software is good but test list sort goog job Quote
Fiery Posted September 19, 2012 Posted September 19, 2012 PhotoWorxx is a very cache and memory dependent benchmark test. I suppose while you overclock your system, you hit a memory bandwidth bottleneck. It looks like it is based on DDR2-800 memory (issue #1), and also it has the IGP part of the chipset activated (issue #2). If you cannot overcome the memory bottleneck, then no matter how you raise the CPU core clock, the PhotoWorxx results will not increase considerably. 1 Quote
