Memory Stats Not Displaying in Sensor Panel
Mukul990
Hi All,
My First post here. Unfortunately it's related to a problem i am facing in my Sensor Panel.
It is not displaying memory related stats ( Speed, Clock, FSB etc. ) It is displaying usage stat properly though.
This is how it was Earlier:
This is how it is now:
Sensor Panel Manager has correct sensors selected:
I have re-added them as well as duplicated them but the situation is same.
Aida64 is otherwise able to detect the RAM and displays the specs. Only issue is with the sensor panel:
Only Hardware change i did was changing the processor from Intel 10th Gen to 11th Gen. Panel detected and displayed it correctly.
Any help would be really appreciated. Thanks in advance :)
On 6/12/2022 at 9:33 PM, Mukul990 said:
Hi All,
Do you have those information properly displayed on the AIDA64 / main menu / Tools / CPUID panel?
