GPU MEMORY CLOCK missing from OSD panel [EVGA GeForce RTX 3080 FTW3]
GPU Memory Clock OSD item *is* present and checked; however, it doesn't appear in the OSD panel itself. This has been going on for several builds. I'm currently on 6.70.6022 BETA (June 9, 2022) and decided to finally give in and post here in the forums about it.
Please upgrade to the latest beta version of AIDA64 Extreme available at:
Let me know if it helps.
Thank you for the quick response, Fiery.
As it states in my OP, I'm already on Version: 6.70.6022 beta (Jun 09, 2022).
My info from Video Debug --> NVIDIA GPU Registers...
------[ Versions ]------
Program Version : AIDA64 Extreme v6.70.6026 Beta
BenchDLL Version: 4.5.868.8-x64
Windows Version : Microsoft Windows 11 Pro 10.0.22000.739 (64-bit)
GetProductInfo  : 0x00000030
------[ Video Adapters ]------
EVGA RTX 3080 FTW3 Ultra Gaming (10G-P5-3897) [10DE-2206 / 3842-3897 / Rev A1]
------[ Video Driver ]------
nvapi.dll: 30.0.15.1296 - nVIDIA ForceWare 512.96
C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_3340992f43425889\nvldumdx.dll|||C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_3340992f43425889\nvldumdx.dll|||C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_3340992f43425889\nvldumdx.dll|||C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_3340992f43425889\nvldumdx.dll|||C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_3340992f43425889\nvldumd.dll|||C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_3340992f43425889\nvldumd.dll|||C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_3340992f43425889\nvldumd.dll|||C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_3340992f43425889\nvldumd.dll
------[ nVIDIA GPU #1 @ mem A0000000 ]------
Video Adapter = EVGA RTX 3080 FTW3 Ultra Gaming (10G-P5-3897)
GPU Code Name = GA102-200-A1
PCI Device    = 10DE-2206 / 3842-3897 [Rev A1]
GPU Clocks   = 1800 / 0 / 0 MHz
Memory Clock = 1187 MHz
GPU    Base Clock = 13500 kHz
Shader Base Clock = 13500 kHz
Memory Base Clock = 13500 kHz
nvidia-000000 = B72000A1  [GA102]
nvidia-001538 = 800003FF
nvidia-001704 = 8027FF91
nvidia-001714 = C027FF92
nvidia-00E114 = 0000021C
nvidia-00E118 = 0000021C
nvidia-00E11C = 00000001
nvidia-00E120 = 00000000
nvidia-020008 = 00002E04
nvidia-020014 = 023801E1
nvidia-0200C4 = 000000D8
nvidia-0200C8 = 00000000
nvidia-0200D8 = 010000D8
nvidia-0200DC = 00000000
nvidia-020340 = 0000C0A0
nvidia-020344 = 000080A0
nvidia-020348 = 00000360
nvidia-020400 = 0000003E
nvidia-021000 = FFFFFFCF
nvidia-022400 = 00000000
nvidia-022430 = 00000007
nvidia-022434 = 00000006
nvidia-022438 = 00000006
nvidia-02243C = 00000006
nvidia-022440 = 00000004
nvidia-088000 = 220610DE  [GA102]
nvidia-08A000 = 1AEF10DE
nvidia-100714 = 00000069
nvidia-101000 = 00400080
nvidia-10100C = 02013000
nvidia-120070 = 00100001
nvidia-120074 = 00000005
nvidia-120078 = 00000006
nvidia-122634 = 00000008
nvidia-300000 = EB7FAA55
nvidia-310000 = 1CAD1DBB
nvidia-700000 = FA020001
nvidia-7E0000 = 00000008
------[ nVIDIA GPU #1 / ForceWare Properties ]------
Memory Type             = 15 (GDDR6X)
Memory Vendor           = 10 (Micron)
Memory Bank Count       = 1
Memory Bus Width        = 320-bit
GPU / MC / VE / BI Load = 35 / 17 / 0 / 4
VPE Count               = 0
Shader Pipe Count       = 6
Shader SubPipe Count    = 34
Total SP Count          = <unknown>
Total TPC Count         = 0
Total SM Count          = <unknown>
Core Count              = 8704
ROP Count               = 96
Partition Count         = 5 (mask: 00000037)
Fan RPM                 = <unknown>
Fan Duty Cycle          = <unknown>
All Fans RPM & Duty     = 482 RPM / 482 RPM / 41 % / 41 %
Core Voltage            = <unknown>
Core Rail Voltage       = 931250 uV
Current Pstate          = 0
PerfCap Reason          = 16 (Utilization)
Ventura State           = 0 (unsupported)
Physical Frame Buffer Size = 10485248 KB
Virtual  Frame Buffer Size = 10485760 KB
Total / Free Video Memory  = 10485760 KB / 6208468 KB
------[ nVIDIA GPU #1 / ForceWare Clocks (old) ]------
Perf. Levels   = 5
Active Profile = 4
curr-core/shader/mem-0 = 420 MHz / 0 MHz / 405 MHz
curr-core/shader/mem-1 = 420 MHz / 0 MHz / 810 MHz
curr-core/shader/mem-2 = 435 MHz / 0 MHz / 5001 MHz
curr-core/shader/mem-3 = 435 MHz / 0 MHz / 9251 MHz
curr-core/shader/mem-4 = 435 MHz / 0 MHz / 9501 MHz [Active]
orig-core/shader/mem-0 = 420 MHz / 0 MHz / 405 MHz
orig-core/shader/mem-1 = 420 MHz / 0 MHz / 810 MHz
orig-core/shader/mem-2 = 435 MHz / 0 MHz / 5001 MHz
orig-core/shader/mem-3 = 435 MHz / 0 MHz / 9251 MHz
orig-core/shader/mem-4 = 435 MHz / 0 MHz / 9501 MHz [Active]
Perf. Levels   = 5
Active Profile = 4
------[ nVIDIA GPU #1 / ForceWare Clocks (new) ]------
Perf. Levels   = 1
Active Profile = 255
curr-core/mem-0 = 1800 MHz / 9501 MHz
orig-core/boost/mem-0 = 1440 MHz / 1800 MHz / 9501 MHz
Perf. Levels   = 1
------[ nVIDIA GPU #1 / BIOS Info ]------
BIOS Version   = 94.02.42.80.16
Signon Message = PG132 SKU 30 VGA BIOS
Bootup Core Clock   =    0 MHz
Bootup Shader Clock =    0 MHz
Bootup Mem Clock    =    0 MHz
Ref. Clock 4000 =      0 kHz =   0 MHz *4
Ref. Clock 4008 =      0 kHz =   0 MHz *4 [Memory]
Ref. Clock 4010 =      0 kHz =   0 MHz *4
Ref. Clock 4018 =      0 kHz =   0 MHz *4
Ref. Clock 4020 =      0 kHz =   0 MHz *4 [Shader]
Ref. Clock 4028 =      0 kHz =   0 MHz *4 [GPU]
Ref. Clock 4030 =      0 kHz =   0 MHz *4
Ref. Clock 4038 =      0 kHz =   0 MHz *4
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Core Voltage   = 0.00 V
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =  125 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    1 MHz
Shader Clock   = 81289852 MHz
Mem Clock      = 81288380 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    1 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    1 %
Core Clock     = 81459696 MHz
Shader Clock   = 81459712 MHz
Mem Clock      = 81459696 MHz
Geom. Delta    = 13184505 MHz
Fan Speed      =  275 %
Core Clock     = 258273004 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      = 1800 %
Core Clock     = 9501 MHz
Shader Clock   = 161589928 MHz
Mem Clock      = 252608916 MHz
Geom. Delta    =    0 MHz
Fan Speed      = 283139904 %
Core Clock     = 161591264 MHz
Shader Clock   = 256763244 MHz
Mem Clock      = 161570064 MHz
Geom. Delta    = 161919356 MHz
Fan Speed      = 262418424 %
Core Clock     = 232221220 MHz
Shader Clock   = 161779112 MHz
Mem Clock      = 231940612 MHz
Geom. Delta    = 262960724 MHz
Fan Speed      = 161988600 %
Core Clock     =    0 MHz
Shader Clock   = 252254052 MHz
Mem Clock      = 252324504 MHz
Geom. Delta    = 281565008 MHz
Fan Speed      = 228282812 %
Core Clock     = 230579144 MHz
Shader Clock   = 231984928 MHz
Mem Clock      = 261140416 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Diode Gain Mul        = 0
Diode Gain Div        = 0
Diode Offset Mul      = 0
Diode Offset Div      = 0
Diode Offset Bin Mul  = 0
Diode Offset Bin Div  = 1
Temp Compensation Mul = 0
Temp Compensation Div = 1
Max Div               = 0
Measured Temp Threshold (Raw)   = 0
Measured Temp Threshold (Int)   = 0 Celsius
Measured Temp Threshold (Float) = 0 Celsius
BIOS Temp Threshold             = 125 Celsius
Measured Diode Temp (Raw)       = 0
Measured Diode Temp (Int)       = 0 Celsius
Measured Diode Temp (Float)     = 0 Celsius
Diode Temp by ForceWare         = 60 Celsius
------[ NVAPI GPU Handles ]------
GPU Count = 1
GPU #1 = 00000100
------[ nVIDIA GPU #1 / Thermal Settings V2 ]------
Sensor Count = 1
Sensor #0 / Controller   = GPU Internal
Sensor #0 / Target       = GPU Core
Sensor #0 / Current Temp = 60 Celsius
------[ nVIDIA GPU #1 / Thermal Settings V1 ]------
Sensor Count = 1
