fixed: Incorrect Voltage Values (ECS Z77H2-A2X)
If it's possible, please go to the BIOS Setup, navigate to the PC Health Status or HW Monitor page, and note down all temperature, voltage and fan speed values your motherboard is monitoring, including their current value. Those values would help us to figure out the necessary sensor register values and ratios to make sure AIDA64 provides accurate readings.
Hi Fiery,
So i upgraded to latest version and now voltages from BIOS are shown correctly. ty :)
I can see that there is no 3.3V,5V and12V readings, so i guess they are not supported by this MBO.
Is it because of sensor type or is it just laziness from ECS side?
Jure
Hi Fiery,
Jure
Thank you for the feedback. +3.3V, +5V and +12V are not supported, because of ECS's decision. Any sensor chips could monitor those rails.
