byw7 Posted December 14, 2012 Posted December 14, 2012 Platform Controller Hub = PCH 1. What indicates this? 2. What temperature it is normal? 3. Which is too high? Kind Regards Quote
Fiery Posted December 14, 2012 Posted December 14, 2012 PCH is the chipset component of your motherboard. It tends to run a bit hotter than processors, especially at idle. Anything above 80 Celsius is considered high for chipsets, and beyond 90 Celsius is considered critical. Regards, Fiery 1 Quote
byw7 Posted December 14, 2012 Author Posted December 14, 2012 Thanks for the answer. Regards byw7 Quote
kpo6969 Posted January 4, 2013 Posted January 4, 2013 I have an Asrock Z77 Extreme4 and my PCH Diode has never changed once from 43C. That doesn't seem correct. Not even one degree up or down. Quote
Fiery Posted January 4, 2013 Posted January 4, 2013 I have an Asrock Z77 Extreme4 and my PCH Diode has never changed once from 43C. That doesn't seem correct. Not even one degree up or down. Have you tried the latest beta version of AIDA64 Extreme Edition? It's available for download at: http://www.aida64.com/downloads/aida64extremebuild2256z8l9qktcjyzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. If it's still stuck, then your motherboard may not be able to measure PCH temperature. Quote
kpo6969 Posted January 6, 2013 Posted January 6, 2013 My yearly subscription ran out on Jan 1 so I can't try it yet. Thank you. Quote
byw7 Posted April 25, 2013 Author Posted April 25, 2013 Hello Fiery, I have a new PSU. With the new PSU shows my PCH Diode 59 °C - 64 °C . Is it still harmless? Regards Quote
Fiery Posted April 25, 2013 Posted April 25, 2013 Hello Fiery, I have a new PSU. With the new PSU shows my PCH Diode 59 °C - 64 °C . Is it still harmless? Regards Yes, it is. Quote
decllipter Posted October 25, 2013 Posted October 25, 2013 It's ok for some cpu-s. What cpu you have? I have i7 740qm and temp of phc go to 80 degrees max temp according to intel site is 100 degrees for this cpu ,and yes iam talking about chipset or PHC . Go on intel or amd and check your procesor,chipset should be named TJUNCTION. Sorry for my englesh. Hope i help you. BB Quote
Deivs Posted March 28, 2015 Posted March 28, 2015 It's ok for some cpu-s. What cpu you have? I have i7 740qm and temp of phc go to 80 degrees max temp according to intel site is 100 degrees for this cpu ,and yes iam talking about chipset or PHC . Go on intel or amd and check your procesor,chipset should be named TJUNCTION. Sorry for my englesh. Hope i help you. BB Thanx for info Quote
cedric0115 Posted August 27, 2019 Posted August 27, 2019 Hello i use a HP Compaq 15 Notebook PC and my temperature of PCH Diode is 84C Quote
Fiery Posted August 28, 2019 Posted August 28, 2019 15 hours ago, cedric0115 said: Hello i use a HP Compaq 15 Notebook PC and my temperature of PCH Diode is 84C Mobile computers tend to work at higher thermal rates than desktop computers. A PCH temperature of 84 Celsius is not considered critical for a mobile computer. Quote
