Wallerz Posted July 22, 2022 Posted July 22, 2022 Hi, I don't seem to be able to add fan speeds to the sensor panel. They are missing. All the fan speeds show up in the BIOS but there is nothing in the list of sensor options. I have attached the sensor debug if that helps. Please an you help? isasensordump.txt Quote
Fiery Posted July 22, 2022 Posted July 22, 2022 29 minutes ago, Wallerz said: Hi, I don't seem to be able to add fan speeds to the sensor panel. They are missing. All the fan speeds show up in the BIOS but there is nothing in the list of sensor options. I have attached the sensor debug if that helps. Please an you help? isasensordump.txt 8.8 kB · 1 download Can you see any fan RPM readings on the Computer / Sensor page of AIDA64? BTW, are you sure at least one of the fans is spinning when you try to add them to your SensorPanel? Quote
Wallerz Posted July 22, 2022 Author Posted July 22, 2022 The only ones I can see are the GPU fans. All other fans are spinning. They are Lian li SL120's, all running through a hub which is then plugged into the motherboard Quote
Wallerz Posted July 22, 2022 Author Posted July 22, 2022 6 hours ago, Fiery said: Can you see any fan RPM readings on the Computer / Sensor page of AIDA64? BTW, are you sure at least one of the fans is spinning when you try to add them to your SensorPanel? The only ones I can see are the GPU fans. All other fans are spinning. They are Lian li SL120's, all running through a hub which is then plugged into the motherboard Quote
