Posted (edited)
So after installing the latest beta build to fix the d5 next pump not showing, I noticed my sensor panel being slow to update, feeling frozen. Slow to start/show on boot.
Looking through the forums I found old posts asking to show sensor profiling dumps, so I looked at those.
'Corsair RMi' is taking for-F'ing-ever to update. When I pull the psu's usb plug, it's back to being snappy.
How can I fix this? I wasn't having this on 6.70 build, but it's also happening on the 6.75 stable build.
Thank you.
sensorprof.txt sensorprof2.txt
Edited by GrimmReaperNL
added info.
Thank you.
We've never seen such anomaly about Corsair RMi PSU's :(  The only workaround you can apply is disabling (unchecking) the option Corsair HXi/RMi sensor support in AIDA64 / main menu / File / Preferences / Stability.
