the rat Posted November 6, 2012 Report Share Posted November 6, 2012 I just upgraded to version 2.70.2200 and now my CPU core temp no longer regester they are all at 0. This is on a ASRock 970 Extremr4 with 955 processor. Anyone else encounter this? I tryed reinstalling but still nothing I can always go back to earler version, just wanted to see if anyone else had solved this issue. Quote Link to comment Share on other sites More sharing options...
Fiery Posted November 6, 2012 Report Share Posted November 6, 2012 Usually activating ACC (Advanced Clock Calibration) causes such anomalies. It's unfortunately completely normal, and it's due to a hardware limitation of AMD processors. You could see the same zero temperature readings in other software as well. BTW, ACC is used for e.g. unlocking disabled cores of AMD processors Regards, Fiery Quote Link to comment Share on other sites More sharing options...
the rat Posted November 6, 2012 Author Report Share Posted November 6, 2012 Thank you Fiery somehow that was turned on in the BIOS I turned ACC off and all is working fine. I have the latest beta installed so all is not wasted time I learned something new today also. Thanks Mike Quote Link to comment Share on other sites More sharing options...
