Frustrated Posted November 10, 2012 Posted November 10, 2012 New member here. Old user of Everest Extreme Edition. Now trying to migrate to AIDA64 Extreme Edition. Having a problem with the tray icons, ones that show things like mobo and processor core temperatures. In Everest, the numbers inside these icons which show the temperature number were large and very readable. In AIDA64, the font is unreadable. How do I change the font type/size for these, so the icons are readable again? The attachment shows the AIDA64 icons on left side, and Everest icons on right side. The difference is HUGE! Help! Thanks. Quote
Fiery Posted November 11, 2012 Posted November 11, 2012 That's how it should look like, to make sure the text fits the icon area. As you can see, on the right-hand side the text doesn't fit in the Everest sensor icon: it's the wrong way to display the text there I suppose the visual distortion is caused by a non-standard DPI setting you applied. Is that the case? Quote
Frustrated Posted November 11, 2012 Author Posted November 11, 2012 Hi Fiery, Thanks for the suggestion. I see you are the AIDA64 developer? I use a 27" LCD screen, and thus use 120DPI desktop font (instead of the standard 96 DPI font). The reason is that otherwise the icons would be too miniscule to read. I tried your suggestion of changing to standard font (96DPI), and then I also tried 144DPI to see what would happen. I use XP Pro SP3, and rebooted each time. The font in the tray icons in Everest, under any of the 3 resolutions tried, is very readable. Clarity and readablility is critical for the icons displaying critical info about your computer. Yes, the font runs off the right side of the Everest icons, but is still way more readable than the AIDA64 font. Actually the larger font is perfect, unless there is a period "." in the text, like in CPU speed. Because the icon can only handle 2 characters, not 3. In AIDA64, the font is distorted under all 3 resolutions tried. The font just gets larger or smaller with changes to the desktop font size, but equally distorted at all settings. Is there an easy font change setting somewhere that I can try? Since AIDA64 is a newer version of Everest, I do not understand why the icons differ so much in the new version. I could live with the smaller fonts, but need to lose the distortion and have a normal looking font in the icons. Is there a setting change I can try, or is this a bug? Any other suggestions to try? Your help is much appreciated. Thanks. Quote
Fiery Posted November 15, 2012 Posted November 15, 2012 We've checked it with both AIDA64 and Everest (last version, v5.50), but we haven't seen a difference in the icons readability at 120dpi. What version of Everest did you use when you made the screen shot above? Quote
Frustrated Posted November 16, 2012 Author Posted November 16, 2012 Everest Ultimate Edition 5.30.1900 Quote
Fiery Posted November 16, 2012 Posted November 16, 2012 Thank you. We've changed the sensor icons font type and font size at 120+ dpi settings, to make it easier to read without visual distortions, and with the text fitting in the icons area. Please upgrade to the latest beta version of AIDA64 Extreme Edition available at: http://www.aida64.co...15vk0gp7mfzyzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. Thanks, Fiery Quote
Frustrated Posted November 18, 2012 Author Posted November 18, 2012 Hello Fiery, That update fixed the bug. It seems to display perfectly now. Thank you so much for fixing it. Quote
