Why my Aorus Xtreme 2080TI cant read MEMORY TEMPERATURE/VRAM TEMP in sensor panel?!
Please help, I tryed multiple versions didnt help...
Note: all other apps such as HWinfo64, GPU Z etc can read GPU memory temp without a problem.
Thanks forward for the help
Please right-click on the bottom status bar of AIDA64 main window --> Video Debug --> nVIDIA GPU Registers. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first.
Also right-click on the bottom status bar of AIDA64 main window --> Video Debug --> nVIDIA SMBus Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post.
  • Fiery changed the title to Aorus Xtreme 2080TI no VRAM temperature sensor?!
 Also, if needed, I can pay to "unlock" support for VRAM temperature sensor monitoring on my GPU because it is really really important to me!
I am gaming on 1440P and GPU VRAM can get rly rly hot so I would like to monitor those temps...
Hope you understand :)
Idk if u will see what I sent u so I respond like this once again :)
I don't think your video card supports measuring VRAM temperature.  Can you please shot a screenshot of HWiNFO64 where it can indeed measure that thermal spot?
Can you please help me with that? I would really appriciete it!
We've checked it, but we cannot find a method to measure VRAM temperature for your video card :(
Is there any chance I can pay you and you make it work? I really really need VRAM temperature reading on my sensor panel!
It's not about money, but the lack of skills on our part I suppose :) We'd love to add it for $0 as long as someone tells us what has to be done.
Ohh okay... Nvm then, thanks anyways for reply, I really appreciate that!
