pyra-c Posted November 16, 2022 Share Posted November 16, 2022 I have a super large computer case, so I was wanting at least a 10" panel. Does anyone have any good recommendations on LCD panels that are at least 10" and support AIDA64? Here is my tower: Thermaltake Tower 900 Snow Edition Here is the screen I purchased: https://www.amazon.com/gp/product/B06Y8SSQG5/ref=ask_ql_qh_dp_hza AOC I1601FWUX 15.6" USB-C powered portable monitor Full HD 1920x1080 IPS SmartCover, AutoPivot (for devices w/ USB-C DP Alt Mode only) Screen Size 15.6 Inches Display Resolution Maximum 1920 x 1080 Pixels Brand AOC Special Feature Pivot Adjustment, Blue Light Filter, Anti-Glare Coating, Tilt Adjustment, Flicker-Free Refresh Rate 60 About this item **USB-C DP Alt Mode on host device is REQUIRED, there is NO HDMI input on this monitor** Please check with your device manufacturer if it supports DisplayPort Alternative Mode. Please install DisplayLink software to use. Aspect Ratio is 16:9; Viewing Angle is 160/160 AOC 16-inch class (15.6” viewable) USB-C portable monitor with IPS screen and full HD 1080P (1920x1080) resolution Simplify your connectivity with one single USB-C cable that powers and delivers video signal to the monitor (Note: This product does not operate with USB 2. 0 and 3. 0 adapters. USB-C Alt Mode required on your device) Extremely slim (only 0.35 inches) and lightweight (under 1.8 pounds) making it easy to carry, incredibly portable. Power Consumption On - 8 watt. Power Consumption Standy - 0.5 watt Comes with smart cover that protects the display when not in use, and turns into a flexible screen holder in portrait or landscape orientation Auto-Pivot detects orientation of the monitor and pivots the display when orientation is changed (DisplayLink driver installation required) Low-blue light mode that protects your eyes from potentially harmful blue spectrum of lights from the display Quote Link to comment Share on other sites More sharing options...
pyra-c Posted November 16, 2022 Author Share Posted November 16, 2022 Here is the screen I ordered: AOC I1601FWUX 15.6" USB-C powered portable monitor Full HD 1920x1080 IPS SmartCover & AutoPivot (for devices w/ USB-C DP Alt Mode only) Screen Size 15.6 Inches Display Resolution Maximum 1920 x 1080 Pixels Brand AOC Special Feature Pivot Adjustment, Blue Light Filter, Anti-Glare Coating, Tilt Adjustment, Flicker-Free Refresh Rate 60 About this item **USB-C DP Alt Mode on host device is REQUIRED, there is NO HDMI input on this monitor** Please check with your device manufacturer if it supports DisplayPort Alternative Mode. Please install DisplayLink software to use. Aspect Ratio is 16:9; Viewing Angle is 160/160 AOC 16-inch class (15.6” viewable) USB-C portable monitor with IPS screen and full HD 1080P (1920x1080) resolution Simplify your connectivity with one single USB-C cable that powers and delivers video signal to the monitor (Note: This product does not operate with USB 2. 0 and 3. 0 adapters. USB-C Alt Mode required on your device) Extremely slim (only 0.35 inches) and lightweight (under 1.8 pounds) making it easy to carry, incredibly portable. Power Consumption On - 8 watt. Power Consumption Standy - 0.5 watt Comes with smart cover that protects the display when not in use, and turns into a flexible screen holder in portrait or landscape orientation Auto-Pivot detects orientation of the monitor and pivots the display when orientation is changed (DisplayLink driver installation required) Low-blue light mode that protects your eyes from potentially harmful blue spectrum of lights from the display Quote Link to comment Share on other sites More sharing options...
Fiery Posted November 16, 2022 Share Posted November 16, 2022 13 hours ago, pyra-c said: I have a super large computer case, so I was wanting at least a 10" panel. Does anyone have any good recommendations on LCD panels that are at least 10" and support AIDA64? Here is my tower: Thermaltake Tower 900 Snow Edition Here is the screen I purchased: 10+ inch screens typically have a HDMI or USB connection and appear under Windows as a secondary monitor. In which case you don't need any special tricks, you can simply use AIDA64 SensorPanel. Quote Link to comment Share on other sites More sharing options...
