ASUS Prime X370-Pro - Chassis fan RPM monitoring work at startup, then after a few minutes stops.
Trayal
 Share
I am a new AIDA64 user, and just got my panel setup and working. However I've noticed an odd problem: a few minutes after AIDA64 startup, my fans, which are connected directly to the motherboard headers, will suddenly spin up to 100% speed even when the system is sitting at idle. I've been using this motherboard since 2017 when it was released and this never happened before. I also noticed that the fan speed monitoring will also stop working (0 RPM reported) on the lcd panel at the same time. This phenomenon never happened before I installed AIDA64, and will ONLY happen when I start up AIDA64 (after a delay of 10 - 15 minutes).
When this happens, the only way to restore normal fan operation is to shut the system down and then turn it back on. Restarts won't work. It looks like AIDA64 is somehow interfering with the BIOS function. I haven't seen this with other monitoring apps (like HW Monitor).
ISA dump below. This was taken while fan monitoring is NOT working. If a before/after comparison is needed, I can get an ISA dump while things are working properly before the issue is triggered.
------[ Versions ]------
Program Version : AIDA64 Extreme v6.80.6200
BenchDLL Version: 4.6.873.8-x64
Windows Version : Microsoft Windows 10 Pro 10.0.19045.2311 (64-bit)
GetProductInfo  : 0x00000030
Motherboard ID      : <DMI>
Motherboard Model   : Asus Prime X370-Pro
Motherboard Chipset : AMD X370, AMD K17.7 FCH, AMD K17.7 IMC
DMI MB Product      : PRIME X370-PRO
DMI MB Version      : Rev X.0x
DMI MB Serial       : 170296198101528
DMI SYS Product     : System Product Name
DMI SYS Version     : System Version
DMI SYS Serial      : System Serial Number
DMI BIOS Version    : 6042
ITE SuperIO Port           = 2Eh
ITE SuperIO HWMonitor Port = 0290h     (    0290h /     0000h)
ITE SuperIO HWMonitor MMIO = F7000000h (F7000000h / 00000000h)
ITE SuperIO Device ID      = 8665h     (    8665h /     0000h)
ITE SuperIO Version        = 06h       (      06h /       00h)
Winbond SuperIO Port              = 00h
Winbond SuperIO Device ID         = 0000h (0000h / 0000h)
ASpeed SuperIO Port = 00h
------[ LM78 ISA Sensor Device at 0290 ]------
0000  09 90 FF 93  00 00 0E 1D  1D 1D 1D 05  05 FF 34 A5
0010  05 05 05 05  05 05 05 05  FF 01 02 05  2B 2B 2B 05
0020  81 E5 B4 B4  03 03 03 97  94 42 22 2F  25 2F 2F 96
0030  05 05 05 05  1D 1D 1D 1D  1D 1D 1D 1D  10 10 10 05
0040  10 BE FE 0F  73 BB 6A 00  AD 6A D4 00  5F 40 00 10
0050  FF 38 7F 7F  7F C0 00 00  90 00 00 12  27 27 27 27
0060  80 7F 7F FF  00 00 0F FF  80 16 37 33  91 00 05 33
0070  28 28 28 28  28 00 0F 28  7F 7F 7F 99  00 00 0F 99
0080  FF FF FF FF  00 00 00 00  00 00 00 00  00 90 2C 3E
0090  00 00 2C 4E  01 00 00 FF  42 99 00 2B  2B 30 2B 00
00A0  7F 7F 7F 80  00 00 0F 80  80 23 4B 66  00 00 0F 66
00B0  CE 50 00 00  C8 9F 7E DF  FF FF FF FF  FF FF FF FF
00C0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF 01
00D0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF 01
   0029 002A 002B
T:   66   34   47
T:   66   34   47
T:   66   34   47
T:   66   34   47
T:   66   34   47
T:   66   34   47
T:   66   33   47
T:   66   34   47
T:   66   34   47
T:   66   33   47
   0020 0021 0022 0023 0024 0025 0026 0027 0028
V:  7E   E5   B5   B5   03   03   03   96   94   [ VID = 1.10000 V ]
V:  7E   E5   B5   B4   03   03   03   96   94   [ VID = 1.10000 V ]
------[ K15.6/K15.7/K16.6/K17/K17.1/K17.2/K17.3/K17.5/K17.6/K17.7/K18/K19.2/K19.4/K19.5/K21 PM2 at 0CD0 ]------
0000  05 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0010  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0020  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0030  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0040  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0050  00 00 00 00  FF FF FF FF  FF FF FF FF  FF FF FF FF
0060  00 00 00 00  00 00 00 00  00 00 00 FF  FF FF FF FF
0070  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0080  FF FF FF FF  FF FF FF FF  FF FF 00 00  00 00 00 00
0090  00 00 00 00  00 FF FF FF  FF FF FF FF  FF FF FF FF
00A0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00B0  00 FF 00 00  FF 00 00 FF  FF FF FF FF  FF FF FF FF
00D0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF 00 FF 00
00E0  00 00 00 00  00 00 00 00  00 00 00 00  01 00 00 02
00F0  19 0A 02 05  C8 20 80 00  04 06 00 00  08 08 00 02
------[ K15.6/K15.7/K16.6/K17/K17.1/K17.2/K17.3/K17.5/K17.6/K17.7/K18/K19.2/K19.4/K19.5/K21 PM at 0CD6 ]------
0000  77 0B 07 E3  02 04 01 00  14 05 1C 02  06 21 43 55
0010  74 00 50 01  16 00 20 00  42 86 64 A8  40 00 3C 00
0020  20 01 9C 01  A0 00 E0 00  55 00 10 00  80 00 00 00
0030  00 00 00 00  00 00 00 00  00 00 00 00  00 08 01 00
0040  FF FF FF 00  00 00 00 88  21 2B 35 59  00 00 3F 49
0050  00 00 3E 3F  90 00 00 14  01 FF 55 44  00 06 00 00
0060  00 08 04 08  08 08 10 08  20 08 B2 00  FF FF BA 00
0070  01 0B 00 00  17 01 06 19  FF FF 00 00  FF FF E0 80
0080  00 00 26 00  00 00 00 00  00 00 00 00  9E 00 80 00
0090  02 05 02 0B  01 00 10 00  00 10 00 01  00 00 00 00
00A0  00 00 00 00  00 00 00 00  F8 CE FF 00  00 00 00 00
00B0  00 20 84 02  00 00 80 05  88 00 28 00  02 00 52 C0
00C0  00 08 08 00  28 02 00 00  0C 40 28 00  DB B6 6D DB
00D0  00 F4 00 BF  00 00 00 00  00 00 11 00  00 00 00 00
00E0  D8 0C 00 00  03 00 01 00  04 00 01 01  15 14 08 7F
00F0  9C 73 00 00  00 00 00 00  3F 00 F0 FE  00 00 00 00
------[ IT86xx MMIO at F7000000 ]------
0000  09 10 00 00  00 00 0E 1D  1D 1D 1D 05  05 FF 34 A5
0020  7E E5 B5 B4  03 03 03 96  94 42 21 2F  25 2F 2F 96
0080  FF FF FF FF  00 00 00 00  00 00 00 00  00 11 2C 3E
0090  00 00 2C 4E  01 00 00 FF  42 99 00 2B  2B 9F 2B 80
0100  09 10 00 00  00 00 0E 1D  1D 1D 1D 05  05 FF 34 A5
0110  05 05 05 05  05 05 05 05  FF 01 02 05  2B 2B 2B 05
0120  7E E5 B5 B4  03 03 03 96  94 42 21 2F  25 2F 2F 96
0130  05 05 05 05  1D 1D 1D 1D  1D 1D 1D 1D  10 10 10 05
0140  10 BE FE 0F  73 BB 6A 00  AD 6A D4 00  5F 40 00 10
0150  FF 38 7F 7F  7F C0 00 00  90 00 00 12  27 27 27 27
0160  80 7F 7F FF  00 00 0F FF  80 16 37 33  91 00 05 33
0170  28 28 28 28  28 00 0F 28  7F 7F 7F 99  00 00 0F 99
0180  FF FF FF FF  00 00 00 00  00 00 00 00  00 D0 2C 3E
0190  00 00 2C 4E  01 00 00 FF  42 99 00 2B  2B 12 2B 44
01A0  7F 7F 7F 80  00 00 0F 80  80 23 4B 66  00 00 0F 66
01B0  CE 50 00 00  C8 9F 7E DF  FF FF FF FF  FF FF FF FF
01C0  00 06 B6 1C  51 07 31 60  30 FF FF FF  FF FF FF 01
01D0  00 80 44 A1  01 71 C0 84  28 FF FF FF  FF FF FF 01
01E0  65 1E C9 7A  87 7F 06 52  10 C1 5D 64  B7 F1 15 B0
01F0  1F D2 6F 66  01 40 CF EC  A5 0B 78 78  5E 19 5F A0
0200  09 01 00 00  00 00 0E 1D  1D 1D 1D 05  05 FF 34 A5
0210  7F 00 00 00  7F 00 00 00  7F 00 00 00  7F 1A 00 00
0220  2D E9 40 00  7F 00 40 00  7F 00 40 00  7F F3 C0 96
0230  2D D6 60 00  7F 00 60 00  7F 00 60 00  7F 01 01 94
0240  7F 00 00 00  7F 00 00 00  7F 00 00 00  7F 00 00 00
0250  7F 00 00 00  7F 00 00 00  7F 00 00 00  7F 3C 27 27
0260  28 80 00 00  7F 00 00 00  7F 00 00 00  7F 3C 3C 3C
0270  08 0A 00 4C  4B 00 00 00  00 00 7F 99  00 00 0F 99
0280  FF FF FF FF  00 00 00 00  00 00 00 00  00 FF 2C 3E
0290  00 00 2C 4E  01 00 00 FF  40 00 00 00  00 B0 00 60
02A0  7F 7F 7F 80  00 00 0F 80  80 23 4B 66  00 00 0F 66
02B0  CE 50 00 00  C8 9F 7E DF  FF FF FF FF  FF FF FF FF
02C0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF 01
02D0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF 01
02E0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
02F0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0300  09 10 00 00  00 00 0E 1D  1D 1D 1D 05  05 FF 34 A5
0310  05 05 05 05  05 05 05 05  FF 01 02 05  2B 2B 2B 05
0320  7E E5 B5 B4  03 03 03 96  94 42 21 2F  25 2F 2F 96
0330  05 05 05 05  1D 1D 1D 1D  1D 1D 1D 1D  10 10 10 05
0340  10 BE FE 0F  73 BB 6A 00  AD 6A D4 00  5F 40 00 10
0350  FF 38 7F 7F  7F C0 00 00  90 00 00 12  27 27 27 27
0360  80 7F 7F FF  00 00 0F FF  80 16 37 33  91 00 05 33
0370  28 28 28 28  28 00 0F 28  7F 7F 7F 99  00 00 0F 99
0380  FF FF FF FF  00 00 00 00  00 00 00 00  00 2F 2C 3E
0390  00 00 2C 4E  01 00 00 FF  42 99 00 2B  2B 66 2B A1
03A0  7F 7F 7F 80  00 00 0F 80  80 23 4B 66  00 00 0F 66
03B0  CE 50 00 00  C8 9F 7E DF  FF FF FF FF  FF FF FF FF
03C0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF 01
03D0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF 01
03E0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
03F0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
_TZ_.THM0._TMP             :
_TZ_.THM1._TMP             :
_TZ_.THR0._TMP             :
_TZ_.THR1._TMP             :
_TZ_.TZ00._TMP             :
_TZ_.TZ01._TMP             :
_TZ_.RTMP                  :
_TZ_.RFAN                  :
_TZ_.RFAN(0)               :
_TZ_.RFAN(1)               :
_SB_.ATKD._HID             :
_SB_.ATKD.TMPR             :
_SB_.PCI0.LPC0.EC0_.CCTV   :
_SB_.PCI0.LPC0.EC0_.LRPM   :
_SB_.PCI0.LPC0.EC0_.HRPM   :
_SB_.PCI0.SBRG.EC0_.ECPU   :
_SB_.PCI0.SBRG.EC0_.TACH(0):
_SB_.PCI0.SBRG.EC0_.TACH(1):
_SB_.PCI0.SBRG.EC0_.TAH0   :
_SB_.PCI0.SBRG.EC0_.TAH1   :
_SB_.PCI0.SBRG.EC0_.ST00   :
_SB_.PCI0.SBRG.EC0_.SC01   :
_SB_.PCI0.SBRG.EC0_.SC02   :
_SB_.PCI0.SBRG.EC0_.SC03   :
_SB_.PCI0.SBRG.EC0_.SC04   :
_SB_.PCI0.SBRG.EC0_.SC05   :
_SB_.PCI0.SBRG.EC0_.SC06   :
_SB_.PCI0.SBRG.EC0_.TH0R   :
_SB_.PCI0.SBRG.EC0_.TH1R   :
_SB_.PCI0.SBRG.EC0_.F0TS   :
_SB_.PCI0.SBRG.EC0_.F1TS   :
_SB_.PCI0.PIB_.EC0_.TCRT   :
_SB_.PCI0.SBRG.EC0_.CTPM   :
_SB_.PCI0.SBRG.EC__.CPUT   :
_SB_.PCI0.SBRG.EC__.SYST   :
_SB_.PCI0.LPC_.EC0_.CTMP   :
_SB_.PCI0.LPCB.EC0_.CTMP   :
_SB_.PCI0.LPC_.EC0_.TMP1   :
_SB_.PCI0.LPC_.EC0_.TMP2   :
_SB_.PCI0.LPC_.EC0_.TMPI   :
_SB_.PCI0.LPC_.EC0_.TMPV   :
_SB_.PCI0.LPCB.EC0_.A1TP   :
_SB_.PCI0.LPCB.EC0_.A2TP   :
_SB_.PCI0.LPCB.EC0_.FAN0   :
_SB_.PCI0.LPCB.EC__.TS1R   :
_SB_.PCI0.LPCB.EC__.TS2R   :
_SB_.PCI0.LPCB.EC__.TS3R   :
_SB_.PCI0.LPCB.EC__.F1FL   :
_SB_.PCI0.LPCB.EC__.F1FH   :
_SB_.PCI0.LPCB.EC__.F2FL   :
_SB_.PCI0.LPCB.EC__.F2FH   :
_SB_.PCI0.LPC_.H8EC.RTMP   :
_SB_.PCI0.LPC_.H8EC.LTMP   :
_SB_.PCI0.LPC_.H8EC.MTMP   :
_SB_.PCI0.LPC_.H8EC.GTMP   :
_SB_.PCI0.LPCB.H8EC.CTMP   :
_SB_.PCI0.LPCB.H8EC.DTMP   :
_SB_.PCI0.LPCB.H8EC.GTMP   :
_SB_.PCI0.LPCB.H8EC.ITMP   :
_SB_.PCI0.LPCB.H8EC.MTMP   :
_SB_.PCI0.LPCB.H8EC.STMP   :
_SB_.PCI0.LPCB.H8EC.PFAN   :
_SB_.PCI0.LPCB.EC0_.OTPC   :
_SB_.PCI0.LPCB.EC0_.VGAT   :
_SB_.PCI0.LPCB.EC0_.CHPT   :
_SB_.PCI0.LPCB.EC0_.CPUT   :
_SB_.PCI0.LPCB.EC0_.SYST   :
_SB_.PCI0.LPCB.EC0_.DTS1   :
_SB_.PCI0.LPCB.EC0_.DTS2   :
_SB_.PCI0.LPCB.EC0_.DIMM   :
_SB_.PCI0.LPCB.EC0_.FANH   :
_SB_.PCI0.LPCB.EC0_.FANL   :
_SB_.PCI0.LPCB.EC0_.CUTP   :
_SB_.PCI0.LPCB.EC0_.PHTP   :
_SB_.PCI0.LPCB.EC0_.DIMT   :
_SB_.PCI0.LPCB.EC0_.INLE   :
_SB_.PCI0.LPCB.EC0_.PANT   :
_SB_.PCI0.LPCB.EC0_.F0RM   :
_SB_.PCI0.LPCB.EC0_.F0DT   :
_SB_.PCI0.LPCB.EC0_.F1RM   :
_SB_.PCI0.LPCB.EC0_.F1DT   :
_SB_.PCI0.SBRG.EC0_.CUTP   :
_SB_.PCI0.SBRG.EC0_.PHTP   :
_SB_.PCI0.SBRG.EC0_.DIMT   :
_SB_.PCI0.SBRG.EC0_.INLE   :
_SB_.PCI0.SBRG.EC0_.PANT   :
_SB_.PCI0.SBRG.EC0_.F0RM   :
_SB_.PCI0.SBRG.EC0_.F0DT   :
_SB_.PCI0.SBRG.EC0_.F1RM   :
_SB_.PCI0.SBRG.EC0_.F1DT   :
_SB_.SAMB.TMPC             :
_SB_.SAMB.TMPH             :
_SB_.STR0._TMP             :
_SB_.STR1._TMP             :
_SB_.STR2._TMP             :
_SB_.STR3._TMP             :
_SB_.STR4._TMP             :
_SB_.STR5._TMP             :
_SB_.STR6._TMP             :
_SB_.STR7._TMP             :
CPUT                       :
GPUT                       :
SYST                       :
FANT                       :
BATT                       :
Okay, so... this might have been a false alarm. I previously had been using hwinfo64 on this system, and ran the uninstaller before testing out aida64 because I'm a software QA tester by trade and am aware that conflicts can occur if multiple apps are fighting over the same resources. Anyway, apparently the uninstaller just removed the entry from the Programs and Features list but didn't actually take it off the system. I just found it still on the drive, and uninstalled it manually. I will test the issue further and return with the results. Apologies and thanks.
Yes, it sounded like a collision with another monitoring software.
Hello, I decided to check the characteristics of my iPhone (iPhone 13 Pro). I downloaded your application (Aida64) and showed me that all my characteristics are not known and that my phone was assembled in 1970. They also wrote that my iPhone 13 Pro is an iPhone 14.2, please tell me what to do?
Please email me everything to my email: bogdan.makarov999@gmail.com
Edited by Bogdan22527
Things worked well for a couple of days after I removed hwinfo, but the issue just occurred again -- fans spun up to max while system was idle and temps low. Oddly, though, it didn't last a long time before suddenly going back to normal -- a half hour or so. Another difference is that RPM sensing still works rather than dropping to a listed 0. I have scoured my system to double/triple/quadruple check there is no other monitor software on the system this time.
I have noticed one other odd issue. Occasionally, the water pump RPM sensor will just disappear from AIDA64. It's always detected at boot, but sometimes my panel will suddenly read 0 rpm and when I open aida and check the computer -> sensor heading, it's just no longer listed at all. A quick reboot will fix it.
I am working on getting before and after captures, if you would like to take a look  I can post them here when the issue next happens (of course, now that I want it to happen so i can get a dump, it won't happen). I am starting to think both issues may be a BIOS related bugs, but would like a second opinion if possible. Thanks again.
One further detail -- My motherboard temperature dropped to 12c... which isn't at all accurate. Something really weird is going on here...
Unless you have another hardware monitoring software installed (or any portions of e.g. Asus' own monitoring tool left behind), I suspect this is due to a BIOS bug.  Asus X370 and X470 motherboards use a unique & proprietary solution to provide access to sensor registers, and I personally always felt it was a shaky implementation.  The whole interface was quite buggy at the start, and I felt as if Asus' engineers had a hard time to make this work in a way to avoid any collisions with other BIOS layers.
Well, that's a shame; this board has been a tank for 5+ years. I can't justify buying a new board to fix an LCD panel. Oh well.
For what it's worth, ASUS software has never been on this system. I've had good experience with their hardware, but know not to trust their software. I've used CPUID's HWMonitor for years, and more recently HWInfo64, and neither of these have caused any issues at all. Are there any particular modules that I could disable under the stability section in preferences so I could possibly continue to have at least some function on my panel?
 Share
