Bogdan22527 Posted December 7, 2022 Posted December 7, 2022 Hello, I have such a problem that I have almost everything displayed as unknown Basic Properties Device iPhone14,2 Dock Connector Unknown SIM Card Type Unknown Device String iPhone14,2 Device Id D63AP Released 1 Jan 1970 Capabilities Cellular Yes GPS No NFC No Force Touch No Bluetooth Version Unknown Controller Unknown Bluetooth Smart (LE) No Physical Properties Water resistant None Width 0.0 mm Height 0.0 mm Depth 0.0 mm Weight 0 g CPU Properties CPU Unknown Manufacturer Unknown Instruction Set Unknown Microarchitecture Unknown Technology Unknown Core Count 6 Active Core Count 6 GPU Properties GPU Type Unknown GPU Cores 1 Co-processor Properties Co-processor Unknown Storage Information Device Model 256 GB Total Storage 238.30 GB Available Storage 174.57 GB RAM Information Total RAM 5652 MB Available RAM 679 MB Screen Size Screen Size 0.00" Aspect Ratio Unknown Pixel Density 0 PPI Screen Parameters Vertical Resolution 0 Pixels Horizontal Resolution 0 Pixels Contrast Unknown Brightness 0 cd/m² Technology Unknown Refresh Rate Color Gamut Back Camera Resolution Unknown MegaPixels Aperture 0.0 Max Video Resolution Unknown Max Video Speed Optical Stabilization No Max Photo Resolution 4032 x 3024 Shortest Exposure Value 1/66667 sec Longest Exposure Value 1/1 sec Front Camera Resolution Unknown MegaPixels Aperture 0.0 Max Video Resolution Unknown Max Video Speed Unknown Optical Stabilization No Max Photo Resolution 4032 x 3024 Shortest Exposure Value 1/47619 sec Longest Exposure Value 1/1 sec Cellular #1 Carrier Not found #2 Carrier name Beeline Capabilities Unknown Baseband Unknown Assigned IP Addresses Wi-Fi (IPv4) Not Available Wi-Fi (IPv6) Not Available Cellular (IPv4) 11.23.7.84 Cellular (IPv6) Not Available Wi-Fi Details SSID Not Connected BSSID Not Connected Capabilities Unknown Controller Unknown Battery Status Discharging Level 57 % Voltage 0.00 V Capacity 0 mAh Watt hours 0.00 Wh Type Li-Ion Polymer Battery Details Adapter Details Installed OS Operating System iOS Version 16.1.2 Build Number 20B110 Multitasking Yes Current Session Active Time 1d 6h 32m Uptime 0d 14h 7m OS Compatibility Initial OS Version Unknown Max Supported OS Version Unknown AIDA64 for iOS Version 1.38 (765) 1 Quote
Mice007 Posted December 7, 2022 Posted December 7, 2022 It seems the app cannot reach our server to get the updates. Make sure you have internet access from this device and try to (force) close the app and start it again Quote
Bogdan22527 Posted December 7, 2022 Author Posted December 7, 2022 I will wait, thank you, one more question, this problem did not appear because of my phone? Quote
Jaxx Posted December 15, 2022 Posted December 15, 2022 I’m having same issue same iPhone 13 PMax. It’s able to do color tests and the accelerometer barometer altimeter and speedometer are working as does the detection of magnetic fields But it doesn’t recognize device specifics, exactly as posted by OP. While it won’t admit the megapixel count, it does know when I open the about information but won’t admit it’s got GPS and of my several apps for this type of diagnostic testing, it’s the only one that has a discrepancy with storage. That said it also seems to be the only one telling me the truth, including Apple themselves and through settings - general - storage I have a 512GB and all others are saying it’s got 300GB open while yours says it’s using 300GB. I continue to use it because it seems accurate with sensors and resolution/pixel performance on the OLED display. But yeah, I guess I can’t see your servers either. I’ve tried the suggestions and I’m definitely online with a quick connection in North America but no dice with the same as OP’s post. text 2.txt Quote
JDB Posted December 15, 2022 Posted December 15, 2022 I have the same issue with my iPhone 13 mini and my iPad Air (the latest version). I deleted the app and download it but that didn’t resolve the issue. Is this a bug or am I missing something? Quote
