kanuckles Posted December 28, 2022 Posted December 28, 2022 Aida64 extreme will not load,after double clicking the icon the splash screen appears but then gets stuck on the splash screen with it saying checking cpu speeds. I have tried Uninstalling then reinstalling. Also installing older versions and the issue is still present. I also run it as administrator but still no fix. When the freeze happens the only way to remove the splash screen is to go into task manager and end the task.It worked before with no problems. Idk what to do, any input would be greatly appreciated thank you Quote
Fiery Posted December 28, 2022 Posted December 28, 2022 5 hours ago, kanuckles said: Aida64 extreme will not load,after double clicking the icon the splash screen appears but then gets stuck on the splash screen with it saying checking cpu speeds. I have tried Uninstalling then reinstalling. Also installing older versions and the issue is still present. I also run it as administrator but still no fix. When the freeze happens the only way to remove the splash screen is to go into task manager and end the task.It worked before with no problems. Idk what to do, any input would be greatly appreciated thank you What CPU and motherboard do you have? Quote
kanuckles Posted December 28, 2022 Author Posted December 28, 2022 Ryzen 9 5900x and msi mpg gaming edge wifi Quote
kanuckles Posted December 28, 2022 Author Posted December 28, 2022 This issue still persist I have deleted and uninstalled multiple times today and still no fix Quote
