DrPlague Posted January 13, 2023 Share Posted January 13, 2023 Is there a way to save all my work ive done to the sensor panel, so it loads backup when i turn on the pc? thanks Quote Link to comment Share on other sites More sharing options...
Awol Posted January 13, 2023 Share Posted January 13, 2023 Hi mate* Having issues sending the panel files to you, issue at my end. Any hows here are some 1480*320 panel files for you to have a look at and adjust to your needs. 2022-12-22 Current.sensorpanel 538020780_2023-01-13V2.sensorpanel 1853865741_Panel2.sensorpanel Panel 3.sensorpanel 801855320_Panel4.sensorpanel ThemelyRetro.sensorpanel 1 Quote Link to comment Share on other sites More sharing options...
Fiery Posted January 13, 2023 Share Posted January 13, 2023 3 hours ago, DrPlague said: Is there a way to save all my work ive done to the sensor panel, so it loads backup when i turn on the pc? thanks Once you change anything about your SensorPanel, the work is saved to the AIDA64.INI file that you can find in AIDA64 installation folder. You can backup that file if you need to save your work to a safe place. Quote Link to comment Share on other sites More sharing options...
DrPlague Posted January 14, 2023 Author Share Posted January 14, 2023 59 minutes ago, Fiery said: Once you change anything about your SensorPanel, the work is saved to the AIDA64.INI file that you can find in AIDA64 installation folder. You can backup that file if you need to save your work to a safe place. thanks,is that automatically saved then? Quote Link to comment Share on other sites More sharing options...
DrPlague Posted January 14, 2023 Author Share Posted January 14, 2023 2 hours ago, Awol said: Hi mate* Having issues sending the panel files to you, issue at my end. Any hows here are some 1480*320 panel files for you to have a look at and adjust to your needs. 2022-12-22 Current.sensorpanel 162.43 kB · 0 downloads 538020780_2023-01-13V2.sensorpanel 3.3 MB · 0 downloads 1853865741_Panel2.sensorpanel 2.02 MB · 0 downloads Panel 3.sensorpanel 121.79 kB · 0 downloads 801855320_Panel4.sensorpanel 2.08 MB · 0 downloads ThemelyRetro.sensorpanel 107.63 kB · 0 downloads thanks bud. silly question....what do i use to open these files?-aida64? sorry im still new to this program Quote Link to comment Share on other sites More sharing options...
Awol Posted January 14, 2023 Share Posted January 14, 2023 Right click aida64 - preferences - sensor panel It will open a default panel - right click on the panel and select sensor panel manager - click import and select a panel file Quote Link to comment Share on other sites More sharing options...
Fiery Posted January 15, 2023 Share Posted January 15, 2023 On 1/14/2023 at 1:11 AM, DrPlague said: thanks,is that automatically saved then? Yes, it is. Quote Link to comment Share on other sites More sharing options...
Fiery Posted January 15, 2023 Share Posted January 15, 2023 On 1/14/2023 at 1:14 AM, DrPlague said: thanks bud. silly question....what do i use to open these files?-aida64? sorry im still new to this program .sensorpanel files can be imported directly into your SensorPanel layout. Right-click on SensorPanel --> SensorPanel Manager --> Import. Quote Link to comment Share on other sites More sharing options...
