legalan Posted December 9, 2010 Share Posted December 9, 2010 Hello, Don't know whether it's a bug, but I don't see a more suitable place to post... Well, I downloaded a trial version, but most signs are unreadable (to me). Maybe I could change language, but how to do it if I can't read? Example: First menu (I guess that should be "File") looks this way - Ôà ¼ë Does Aida use some special font that I don't have? Quote Link to comment Share on other sites More sharing options...
Fiery Posted December 9, 2010 Share Posted December 9, 2010 No special fonts used in AIDA64. I guess when you adjusted your regional/language settings in Windows, you didn't configure the language for non-Unicode programs to your language. You can easily change the language in AIDA64. Just click on the first menu (File), then select the first menu item from the File menu, and that will lead you to the language selection list. Select English there, press Enter key, and it should work from there An alternative, more "destructive" solution is to completely remove the non-English language support from AIDA64: navigate to AIDA64 installation folder, and delete all files with a filename that starts with "LANG". Also remove the whole folder named "Language" if it exists. Regards, Fiery Quote Link to comment Share on other sites More sharing options...
legalan Posted December 29, 2010 Author Share Posted December 29, 2010 I went to vacation and haven't been on this computer for a while... It wasn't first menu, but I found it (it was fourth). It worked immediately, thank you Quote Link to comment Share on other sites More sharing options...
