FRLICH Posted March 8, 2023 Posted March 8, 2023 I am doing a trial of the software prior to purchase. I am not seeing any of my Corsair fans or Cooler data in the Sensor area. I am wondering if this is because it's a trial or is it not compatible with the Corsair data? Thanks in advance. Quote
Fiery Posted March 8, 2023 Posted March 8, 2023 2 hours ago, FRLICH said: I am doing a trial of the software prior to purchase. I am not seeing any of my Corsair fans or Cooler data in the Sensor area. I am wondering if this is because it's a trial or is it not compatible with the Corsair data? Thanks in advance. Try to enable Corsair Link sensor support in AIDA64 / main menu / File / Preferences / Stability. However, please note that not all Corsair AIO and Commander devices are supported by AIDA64. Quote
FRLICH Posted March 8, 2023 Author Posted March 8, 2023 Thanks for the response. I have checked that setting on and still do not see them being recognized. Quote
DieselSLC Posted March 11, 2023 Posted March 11, 2023 I have most of the current Corsair commander versions and have never seen this work. Up to date as of today. Quote
Zac_Syd Posted March 11, 2023 Posted March 11, 2023 @FRLICH, I have a Corsair build and have the same issues. I reached out to Corsair themselves and their response was that we shouldn't need to use Aida64 as their iCUE software provides this information. They have removed the API function for this so that they force users to use their iCUE software for monitoring temps and everything else. I told them that the reason why I use Aida64 and not their iCUE dashboard, but they did not seem to care. I hope this helps you. Quote
