In Aida64 extreme I enabled the sensor symbols in the
system tray. When the program starts, the GPU temperature
and the GPU ambient temperature are shown correctly for
a short time. However, when the values are refreshed
the first time, those values are shown as zero. It does
not change anymore.
I do remember that I had the same issue with either
Aida32 or Everest years ago. Unfortunately I only
remember that it could be fixed, but I forgot completely
how.
Now it is back in AIDA64. Can you please tell me what to
do? Is it something I have to change or is it a bug
which will be fixed in a later release?
BTW, in the latest version of Everest the GPU temperatures
are monitored correctly on the same hardware.
If you need further information (hardware, ...) let me know.
1) Please let me know you hardware details, especially the video card (or video cards) model.
2) Which version of AIDA64 are you running?
3) Do you have everything else (except for the GPU temperatures) shown correctly on the Sensor page? Please copy-paste the full content of that page into this topic -- or create a screen shot.
Just found it myself.
The video card is a NVidia FX 5700 Go.
In the Preferences -> Stability I had to check
the "nVidia GPU SMBus access through nVidia ForceWare"
option. Now it is shown perfectly well.
