Does Aida64 offer gpu PCIe +12v input monitoring for the 12vhpwr connection? Its in gpuz, its in hwinfo64. Maybe it’s called something different. It’s important these days to watch out for melting terminals on 4090 series nvidia cards. Values less than 11.8 may indicate a problem. Aida64 makes the best program for sensor panels imo, and I was hoping to add this to my layout. Thanks.
Please right-click on the bottom status bar of AIDA64 main window --> Video Debug --> nVIDIA GPU Registers. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first.
Also right-click on the bottom status bar of AIDA64 main window --> Video Debug --> nVIDIA SMBus Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post..
  • Fiery changed the title to Gpu PCIe 12v input voltage sensor? (RTX 4090)
Hey @Fiery is it possible to monitor the 12vhpwr voltage sensor on 4090's or is this something you're planning on adding? I have a 4090 I've yet to install and have been using Aida64 since it was called Everest and would love to continue using it, especially to keep an eye on the 4090's 12vhpwr voltage without the need to run another program like GPUZ. Thanks.
7 hours ago, CycleChris said:
Where? Bottom Status Bar? I have the screen that has File, view, Report, Favorites, tools, Help.
I think I got it, 12v voltage?
Click on "View" next to "File" up in the top left and make sure "Status Bar" box is checked then right click on the bottom status bar in the main Aida64 window and do what he said.
  • 2 months later...
18 hours ago, Mat-UK said:
Did anyone figure this out? I've been trying everything I can think of to show the 12vhpwr voltage in Aida 64 but so far no luck.
Pretty sure they have to add in the ability to do this in an update. I've been using GPU-Z and it's sensors page to keep an eye on my 4090's 12VHPWR voltage
here you go, the 2 dumps needed to implement monitoring the 12VHPWR voltages
------[ Versions ]------
Program Version : AIDA64 Extreme v6.90.6528 Beta
BenchDLL Version: 4.6.882.8-x64
Windows Version : Microsoft Windows 11 Pro 10.0.22621.2134 (64-bit)
GetProductInfo  : 0x00000030
------[ Video Adapters ]------
Gainward RTX 4090 [10DE-2684 / 10B0-F297 / Rev A1]
------[ Video Driver ]------
nvapi.dll: 31.0.15.3699 - nVIDIA ForceWare 536.99
C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_1ddf203f8d876fdf\nvldumdx.dll|||C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_1ddf203f8d876fdf\nvldumdx.dll|||C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_1ddf203f8d876fdf\nvldumdx.dll|||C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_1ddf203f8d876fdf\nvldumdx.dll|||C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_1ddf203f8d876fdf\nvldumd.dll|||C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_1ddf203f8d876fdf\nvldumd.dll|||C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_1ddf203f8d876fdf\nvldumd.dll|||C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_1ddf203f8d876fdf\nvldumd.dll
------[ nVIDIA GPU #1 @ mem 84000000 ]------
Video Adapter = Gainward RTX 4090
GPU Code Name = AD102-300-A1
PCI Device    = 10DE-2684 / 10B0-F297 [Rev A1]
GPU Clocks   = 2520 / 0 / 0 MHz
Memory Clock = 1312 MHz
GPU    Base Clock = 13500 kHz
Shader Base Clock = 13500 kHz
Memory Base Clock = 13500 kHz
------[ nVIDIA GPU #1 / ForceWare Properties ]------
Memory Type             = 15 (GDDR6X)
Memory Vendor           = 10 (Micron)
Memory Bank Count       = 1
Memory Bus Width        = 384-bit
GPU / MC / VE / BI Load = 2 / 1 / 0 / 0
VPE Count               = 0
Shader Pipe Count       = 11
Shader SubPipe Count    = 64
Total SP Count          = <unknown>
Total TPC Count         = 0
Total SM Count          = <unknown>
Core Count              = 16384
ROP Count               = 176
Partition Count         = 6 (mask: 0000003F)
Fan RPM                 = <unknown>
Fan Duty Cycle          = <unknown>
All Fans RPM & Duty     = 0 RPM / 0 RPM / 0 % / 0 %
Core Voltage            = <unknown>
Core Rail Voltage       = 940000 uV
Current Pstate          = 0
PerfCap Reason          = 16 (Utilization)
Ventura State           = <unknown>
Physical Frame Buffer Size = 25153024 KB
Virtual  Frame Buffer Size = 25153536 KB
Total / Free Video Memory  = 25153536 KB / 22765984 KB
------[ nVIDIA GPU #1 / ForceWare Clocks (old) ]------
Perf. Levels   = 5
Active Profile = 4
curr-core/shader/mem-0 = 645 MHz / 0 MHz / 405 MHz
curr-core/shader/mem-1 = 825 MHz / 0 MHz / 810 MHz
curr-core/shader/mem-2 = 825 MHz / 0 MHz / 5001 MHz
curr-core/shader/mem-3 = 825 MHz / 0 MHz / 10251 MHz
curr-core/shader/mem-4 = 825 MHz / 0 MHz / 10501 MHz [Active]
orig-core/shader/mem-0 = 645 MHz / 0 MHz / 405 MHz
orig-core/shader/mem-1 = 825 MHz / 0 MHz / 810 MHz
orig-core/shader/mem-2 = 825 MHz / 0 MHz / 5001 MHz
orig-core/shader/mem-3 = 825 MHz / 0 MHz / 10251 MHz
orig-core/shader/mem-4 = 825 MHz / 0 MHz / 10501 MHz [Active]
Perf. Levels   = 5
Active Profile = 4
------[ nVIDIA GPU #1 / ForceWare Clocks (new) ]------
Perf. Levels   = 1
Active Profile = 255
curr-core/mem-0 = 2520 MHz / 10501 MHz
orig-core/boost/mem-0 = 2235 MHz / 2520 MHz / 10501 MHz
Perf. Levels   = 1
------[ nVIDIA GPU #1 / BIOS Info ]------
BIOS Version   = 95.02.18.80.53
Signon Message = GeForce RTX4090 VGA BIOS
Bootup Core Clock   =    0 MHz
Bootup Shader Clock = 778499 MHz
Bootup Mem Clock    =    0 MHz
Ref. Clock 4000 =      0 kHz =   0 MHz *4
Ref. Clock 4008 =      0 kHz =   0 MHz *4 [Memory]
Ref. Clock 4010 =      0 kHz =   0 MHz *4
Ref. Clock 4018 =      0 kHz =   0 MHz *4
Ref. Clock 4020 =      0 kHz =   0 MHz *4 [Shader]
Ref. Clock 4028 =      0 kHz =   0 MHz *4 [GPU]
Ref. Clock 4030 =      0 kHz =   0 MHz *4
Ref. Clock 4038 =      0 kHz =   0 MHz *4
Core Clock     =    0 MHz
Shader Clock   =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Core Voltage   = 0,00 V
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      = 778499 MHz
Geom. Delta    =    0 MHz
Fan Speed      =  125 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    1 MHz
Shader Clock   = 100688364 MHz
Mem Clock      = 100686780 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    1 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    1 %
Core Clock     = 100858336 MHz
Shader Clock   = 100858352 MHz
Mem Clock      = 100858336 MHz
Geom. Delta    = 13660273 MHz
Fan Speed      =  275 %
Core Clock     = 384502336 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      = 2520 %
Core Clock     = 10501 MHz
Shader Clock   = 382397404 MHz
Mem Clock      = 266130764 MHz
Geom. Delta    =    0 MHz
Fan Speed      = 380457708 %
Core Clock     = 382453864 MHz
Shader Clock   = 380710980 MHz
Mem Clock      = 382372412 MHz
Geom. Delta    = 266611976 MHz
Fan Speed      = 351350812 %
Core Clock     = 351226072 MHz
Shader Clock   = 266556604 MHz
Mem Clock      = 350943264 MHz
Geom. Delta    = 380708344 MHz
Fan Speed      = 382402908 %
Core Clock     =    0 MHz
Shader Clock   = 266260560 MHz
Mem Clock      = 265989652 MHz
Geom. Delta    = 351280304 MHz
Fan Speed      = 382374064 %
Core Clock     = 380579384 MHz
Shader Clock   = 351245248 MHz
Mem Clock      = 347220088 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    = 22765984 MHz
Fan Speed      =    0 %
Core Clock     = 347376332 MHz
Shader Clock   = 347204380 MHz
Mem Clock      = 380536244 MHz
Geom. Delta    = 380833328 MHz
Fan Speed      = 2235 %
Core Clock     = 2520 MHz
Mem Clock      = 10501 MHz
Geom. Delta    =    0 MHz
Fan Speed      = 380709476 %
Core Clock     = 347177272 MHz
Shader Clock   = 382322312 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    1 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     = 65281 MHz
Mem Clock      =    0 MHz
Geom. Delta    = 2520 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    = 10501 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    = 2235 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Shader Clock   = 382364772 MHz
Mem Clock      =    0 MHz
Geom. Delta    = 100700176 MHz
Fan Speed      =    3 %
Core Clock     = 25153536 MHz
Shader Clock   =    1 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      = 382416484 MHz
Geom. Delta    = 25153536 MHz
Fan Speed      =    1 %
Core Clock     =    0 MHz
Shader Clock   = 50331809 MHz
Mem Clock      = -224980816 MHz
Geom. Delta    = 646189278 MHz
Fan Speed      = 1768124508 %
Core Clock     = 1680879967 MHz
Shader Clock   = 1931883576 MHz
Mem Clock      = 909270902 MHz
Geom. Delta    = 1701062245 MHz
Fan Speed      = 808531769 %
Core Clock     = 1633646181 MHz
Shader Clock   = 945905968 MHz
Mem Clock      = 1630942514 MHz
Geom. Delta    = 640951089 MHz
Fan Speed      = 1633890683 %
Core Clock     = 912338224 MHz
Shader Clock   = 1664115001 MHz
Mem Clock      = 761344053 MHz
Geom. Delta    = 875379001 MHz
Fan Speed      = 946103396 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Core Voltage   = 7,50412287910608896E20 V
Fan Speed      = 775102541 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Shader Clock   = 127823872 MHz
Mem Clock      =    0 MHz
Geom. Delta    = 2024824832 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     = 1767982865 MHz
Shader Clock   = 808722520 MHz
Mem Clock      = 1414668388 MHz
Geom. Delta    = 1918990190 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     = 826556684 MHz
Shader Clock   =   49 MHz
Mem Clock      = 1093480496 MHz
Geom. Delta    = 858599984 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     = 1886930208 MHz
Shader Clock   = 909211680 MHz
Mem Clock      = 808334368 MHz
Geom. Delta    = 1936942450 MHz
Fan Speed      =   54 %
Core Clock     =    0 MHz
Shader Clock   = 1294475352 MHz
Mem Clock      = 911361092 MHz
Geom. Delta    = 1192165376 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      = 24576 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     = 1919250450 MHz
Shader Clock   = 1936024431 MHz
Mem Clock      = 1919969652 MHz
Geom. Delta    = 1819634976 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Shader Clock   = 1819634976 MHz
Mem Clock      = 1919250450 MHz
Geom. Delta    =    0 MHz
Core Voltage   = 7,47730572761125985E247 V
Fan Speed      = 7499635 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      = 13500 %
Core Clock     =    0 MHz
Shader Clock   = 2520 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      = 21002 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =  400 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Diode Gain Mul        = 0
Diode Gain Div        = 0
Diode Offset Mul      = 0
Diode Offset Div      = 0
Diode Offset Bin Mul  = 0
Diode Offset Bin Div  = 1
Temp Compensation Mul = 0
Temp Compensation Div = 1
Max Div               = 0
Measured Temp Threshold (Raw)   = 0
Measured Temp Threshold (Int)   = 0 Celsius
Measured Temp Threshold (Float) = 0 Celsius
BIOS Temp Threshold             = 125 Celsius
Measured Diode Temp (Raw)       = 0
Measured Diode Temp (Int)       = 0 Celsius
Measured Diode Temp (Float)     = 0 Celsius
Diode Temp by ForceWare         = 56 Celsius
------[ NVAPI GPU Handles ]------
GPU Count = 1
GPU #1 = 00000100
------[ nVIDIA GPU #1 / Thermal Settings V2 ]------
Sensor Count = 1
Sensor #0 / Controller   = GPU Internal
Sensor #0 / Target       = GPU Core
Sensor #0 / Current Temp = 56 Celsius
------[ nVIDIA GPU #1 / Thermal Settings V1 ]------
Sensor Count = 1
nVIDIA SMBus Dump
------[ nVIDIA GPU #1 / B00-CR1F = 00 ]------
------[ nVIDIA GPU #1 / B00-CR49 = 00 ]------
------[ nVIDIA GPU #1 / B01-CR1F = 00 ]------
------[ nVIDIA GPU #1 / B01-CR49 = 00 ]------
------[ nVIDIA GPU #1 / B02-CR1F = 00 ]------
------[ nVIDIA GPU #1 / B02-CR49 = 00 ]------
------[ nVIDIA GPU #1 / B03-CR1F = 00 ]------
------[ nVIDIA GPU #1 / B03-CR49 = 00 ]------
------[ nVIDIA GPU #1 / B04-CR1F = 00 ]------
------[ nVIDIA GPU #1 / B04-CR49 = 00 ]------
------[ nVIDIA I2C Device GPU #1 / B04-D49 ]------
  0000  00 01 11 02 07 07 07 00 00 00 00 00 00 00 01 00  ................
  0010  01 01 01 01 06 00 00 00 00 00 00 00 00 20 04 04  ............. ..
  0020  00 00 00 01 00 01 00 00 01 00 02 03 03 20 20 20  .............
  0030  04 04 04 00 00 00 00 00 00 00 06 06 06 00 00 00  ................
  0040  20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
  0050  20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
  0060  01 06 F4 01 F4 01 C8 00 C8 00 88 13 00 00 00 64  ...............d
  0070  00 FF 00 64 E8 03 00 00 00 00 00 00 00 00 00 00  ...d............
  0080  00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0090  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00A0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  00B0  05 05 05 05 FF 00 00 00 00 00 FF 00 00 00 00 00  ................
  00C0  FF FF FF FF FF FF FF FF FF FF FF 01 00 00 E8 80  ................
  00D0  5C 0A 68 0A 75 0A 7D 0A 3D 3D 3D 3D D2 0F 74 74  \.h.u.}.====..tt
  00E0  05 00 09 1E 45 C8 00 64 05 FF FF FF FF FF FF 00  ....E..d........
  00F0  FF FF FF FF FF 06 50 41 4C 49 54 20 32 34 30 00  ......PALIT 240.
  0000  0100 1101 0211 0702 0707 0707 0007 0000 0000 0000 0000 0000 0000 0100 0001 0100
  0010  0101 0101 0101 0601 0006 0000 0000 0000 0000 0000 0000 0000 2000 0420 0404 0004
  0020  0000 0000 0100 0001 0100 0001 0000 0100 0001 0200 0302 0303 2003 2020 2020 0420
  0030  0404 0404 0004 0000 0000 0000 0000 0000 0000 0600 0606 0606 0006 0000 0000 2000
  0040  2020 2020 2020 2020 2020 2020 2020 2020 2020 2020 2020 2020 2020 2020 2020 2020
  0050  2020 2020 2020 2020 2020 2020 2020 2020 2020 2020 2020 2020 2020 2020 2020 0120
  0060  0601 F406 01F4 F401 01F4 C801 00C8 C800 00C8 8800 1388 0013 0000 0000 6400 0064
  0070  FF00 00FF 6400 E864 03E8 0003 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
  0080  0100 0001 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
  0090  0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 FF00
  00A0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 05FF
  00B0  0505 0505 0505 FF05 00FF 0000 0000 0000 0000 FF00 00FF 0000 0000 0000 0000 FF00
  00C0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 01FF 0001 0000 E800 80E8 5C80
  00D0  0A5C 650A 0A65 710A 0A73 7D0A 0A7D 3D0A 3D3D 3C3D 3D3C D23D 0FD2 740F 7474 0574
  00E0  0005 0900 1E09 451E C845 00C8 6400 0564 FF05 FFFF FFFF FFFF FFFF FFFF 00FF FF00
  00F0  FFFF FFFF FFFF FFFF 06FF 5006 4150 4C41 494C 5449 2054 3220 3432 3034 0030 0000
------[ Chips Found ]------
GPU1-B04-D49: ***** Unknown Device *****
Total   :    5.1 sec
GPU1-B00:    0.4 sec
GPU1-B01:    0.3 sec
GPU1-B02:    0.8 sec
GPU1-B03:    0.4 sec
GPU1-B04:    1.5 sec
can the 16-pin 12VHPWR voltage already be monitored in AIDA64? any more info needed?
(at the moment i have to use HWINFO as a backup because I cant manage to get the reading in AIDA)
Currently not possible with Aida64, hoping they add the ability in an updated version soon.
  • 5 months later...
59 minutes ago, fossi said:
awesome, excellent news! renewed my license for this, works great 👍
Thank you for your continued support.
