Uberskippy Posted July 22, 2023 Posted July 22, 2023 I have a I7-1200K which has a Alder Lake-S 32EU IGP video processor bult into it, and I have a Separate video card an Acer BiFrost Intel Arc A770 16GGB. The problem is when I try to setup Sensor Panel to monitor my system it is only showing me Video card info for the bult in S 32EU IGP, it will not show me anything for the ARC A770. Under the full AIDA64 it shows the ARC card but it says it is a video adaptor, it list the S 32EU as the GPU even though nothing is hooked up to it. Quote
Fiery Posted July 22, 2023 Posted July 22, 2023 12 hours ago, Uberskippy said: I have a I7-1200K which has a Alder Lake-S 32EU IGP video processor bult into it, and I have a Separate video card an Acer BiFrost Intel Arc A770 16GGB. The problem is when I try to setup Sensor Panel to monitor my system it is only showing me Video card info for the bult in S 32EU IGP, it will not show me anything for the ARC A770. Under the full AIDA64 it shows the ARC card but it says it is a video adaptor, it list the S 32EU as the GPU even though nothing is hooked up to it. Can you see your Arc GPU listed on the Display / GPU page of AIDA64? Are you using the latest version of AIDA64 v6.90? Quote
Uberskippy Posted July 23, 2023 Author Posted July 23, 2023 No the only thing that shows up on the GPU page is "Intel Alder Lake- S 32EU i integrated graphics controller". I am using AIDA64 v6.90.6500. The ARC shows up under Windows Video page and also PCI/AGP video page but not GPU page. I find this funny because I am not using the intergraded video in fact there is a sticker over the video ports (HDMI and DP) on the motherboard saying "do not use" to make sure you use the ARC processor. Quote
