72hundred Posted July 25, 2023 Posted July 25, 2023 Hi, I've recently built a new PC and installed AIDA64, to work with my Logitech G19s. The LCD freezes now and doesn't update regularly (as in update the info on the screen every second or so to keep the graphs live etc). It was working OK on a previous PC that was upgraded from W10 to W11 but on this fresh install it doesn't seem very happy. I've disabled core isolation in W11 and have Logitech Gaming Software 9.04.49 installed. Any suggestions appreciated. EDIT: Just to add more detail; when I start up the PC the screen (on the G19s) seems to load the initial info, but then does not progress - no updates per second as normal, just frozen. It would seem that if I could get it to refresh it would be back working again. Quote
Fiery Posted July 25, 2023 Posted July 25, 2023 2 hours ago, 72hundred said: Hi, I've recently built a new PC and installed AIDA64, to work with my Logitech G19s. The LCD freezes now and doesn't update regularly (as in update the info on the screen every second or so to keep the graphs live etc). It was working OK on a previous PC that was upgraded from W10 to W11 but on this fresh install it doesn't seem very happy. I've disabled core isolation in W11 and have Logitech Gaming Software 9.04.49 installed. Any suggestions appreciated. EDIT: Just to add more detail; when I start up the PC the screen (on the G19s) seems to load the initial info, but then does not progress - no updates per second as normal, just frozen. It would seem that if I could get it to refresh it would be back working again. Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> Sensor Profiling Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Thanks, Fiery Quote
72hundred Posted July 25, 2023 Author Posted July 25, 2023 I tried that and it crashed mid way through, as per screen capture above. Quote
72hundred Posted July 27, 2023 Author Posted July 27, 2023 Hi, I've tried this again and its crashed again (as per image below), is there something else I can try? Quote
