JMicron and SMART readings
dann23
Thank you for the tip. At the first look it still doesn't seem to support ATA passthrough, so we'll need to do a bit more research to find out what's been changed.
I'll get back to you in this topic once we have an update on this matter.
  • 4 weeks later...
hello. I tried but no luck. Does it work when I have raid enabled or is it for AHCI mode?
It should work for both AHCI and RAID. Do you have the latest JMicron driver installed? What version of Windows do you have installed? 32-bit or 64-bit kernel?
Thanks for the info.
1) Please right-click on the bottom status bar of AIDA64 main window --> Disk Debug --> Disk Controllers Dump. Copy-paste the full results into this topic.
2) Then right-click on the bottom status bar of AIDA64 main window --> Disk Debug --> RAID Dump. Copy-paste the full results into this topic.
  • 4 weeks later...
We've done a lot of tweakings about the JMicron RAID support, and also about the AMD SB7xx/SB8xx RAID support as well. Please upgrade to the latest beta version of AIDA64 Extreme Edition available at:
http://www.aida64.com/downloads/aida64extremebuild1255xv4smgwy5bzip
Let me know how it works. Please note that unlike JMicron and Intel RAID drivers, AMD RAID drivers unfortunately do not expose a pass-through function to read SMART attributes (incl. disk temperature) from RAID arrays.
