AIDA64 water temp sensor problem/bug (Asus ROG Strix Z690-E Gaming WiFi)
Hello!
i found a little bug
Aida could not read my T-sensor from starting in to windows i allways must start ASUS Amoury Crate and go to temps after i click that the Sensor appears in AIDA64 every boot i need to do that
Asus Z690 Strix-E and the sensor i connected directly to the mainboard
  • Solution
20 minutes ago, Benni231990 said:
Hello!
Make sure to enable Embedded Controller (EC) bank switching in AIDA64 / main menu / File / Preferences / Stability.
  • Fiery changed the title to AIDA64 water temp sensor problem/bug (Asus ROG Strix Z690-E Gaming WiFi)
