roberto9834 Posted September 11, 2023 Posted September 11, 2023 Is the voltage reading correct, going to 0v at 5v+ and cpu vrin? I didn't have any chash or crash when this reading happened, along with a voltage alarm that I also configured Quote
Fiery Posted September 11, 2023 Posted September 11, 2023 5 hours ago, roberto9834 said: Is the voltage reading correct, going to 0v at 5v+ and cpu vrin? I didn't have any chash or crash when this reading happened, along with a voltage alarm that I also configured Those zero voltage readings seem to be intermittent invalid readings that should be ignored. BTW, the screen shots shows a different software that we are not the authors of. 1 Quote
roberto9834 Posted September 12, 2023 Author Posted September 12, 2023 18 hours ago, Fiery said: Those zero voltage readings seem to be intermittent invalid readings that should be ignored. BTW, the screen shots shows a different software that we are not the authors of. thanks for answering and sorry, I'm using another software because Windows still keeps crashing every now and then when I try to close Aida. but also has the same voltage reading. Quote
Fiery Posted September 12, 2023 Posted September 12, 2023 6 hours ago, roberto9834 said: thanks for answering and sorry, I'm using another software because Windows still keeps crashing every now and then when I try to close Aida. but also has the same voltage reading. We've seen such issues about Gigabyte motherboards, and they were due to a sensor chip malfunction. However, please note that a failed sensor chip doesn't affect the overall system performance or system stability. 1 Quote
