I've been using the sensor panel fine till this afternoon when after a reboot AIDA64 loaded as normal but with no sensor panel displayed.
1. Nothing has been added / removed from the PC; hardware or software.
2. I've rebooted several times.
3. I've forced stopped AID64 and manually started it several times.
4. I've uninstalled AID64, downloaded the current .exe  (v6.92.6600) and tried with that.
5. I've tried #4 using the trial version.
6. I've tried #4 after entering my product key.
7. In the preferences I've reset the position several times.
8. In the preferences I've disabled "Show Sensor", applied and then enabled it again.
9. I've clicked on the status bar and unchecked / checked everything under the HWMon Modules (As suggested on a different bug report)
Any suggestions to what I can try next to get to see the sensor panel again?
Thanks
Posted (edited)
I am exactly in the same situation from this morning.   The only change on my computer was installation of 2023-09 Cumulative Update Preview for Windows 11 Version 22H2 for x64-based Systems (KB5030310).
Update:   I did a power supply shutdown and Aida detected the sensors and sensor panel reappeared.
Edited by Corotan
Status update
Thanks
1) What motherboard, CPU and video card(s) do you have?
2) Does the Computer / Sensor page work, properly showing all sensor readings?
