mugi Posted October 5, 2023 Share Posted October 5, 2023 Hi everyone, I'm trying to find the file for this design but couldn't find it anywhere. Can anyone share it plz? Quote Link to comment Share on other sites More sharing options...
Shephard Posted October 5, 2023 Share Posted October 5, 2023 what size do you need, we don’t have to wait for the owner, but draw it together with you Quote Link to comment Share on other sites More sharing options...
mugi Posted October 5, 2023 Author Share Posted October 5, 2023 Thank your for your replay, 1024*600 Quote Link to comment Share on other sites More sharing options...
Shephard Posted October 5, 2023 Share Posted October 5, 2023 So, the foundation for our common project has been laid, what background would you like to use? Quote Link to comment Share on other sites More sharing options...
mugi Posted October 5, 2023 Author Share Posted October 5, 2023 if it's ok for you I want it to be just like this one plz, I like this design Quote Link to comment Share on other sites More sharing options...
Shephard Posted October 5, 2023 Share Posted October 5, 2023 At the edges it looks like you can adjust the volume level.. Quote Link to comment Share on other sites More sharing options...
Shephard Posted October 5, 2023 Share Posted October 5, 2023 I don’t know all the sensors in this project, and even more so the sensors you want to use, it would be nice to decide the background is a little more complicated, it looks like the color is not uniform blue, I think it will be possible to add the background later, as a separate picture Quote Link to comment Share on other sites More sharing options...
mugi Posted October 5, 2023 Author Share Posted October 5, 2023 I actually don't have much experience with it as it's my first time using these projects but I would be happy with what you can do with it, the more it looks like it the better. It's ok if you want to skip the ones you aren't familiar with or change them with what you think works best Quote Link to comment Share on other sites More sharing options...
mugi Posted October 5, 2023 Author Share Posted October 5, 2023 I found this background, not like the one in the project but it should work Quote Link to comment Share on other sites More sharing options...
Shephard Posted October 5, 2023 Share Posted October 5, 2023 then it may already look like something, with your permission, I would like to rest today, we will continue tomorrow, I hope you have time to get the result Quote Link to comment Share on other sites More sharing options...
JariKoi Posted October 5, 2023 Share Posted October 5, 2023 Post removed by JariKoi Quote Link to comment Share on other sites More sharing options...
Shephard Posted October 5, 2023 Share Posted October 5, 2023 6 minutes ago, JariKoi said: Почему бы не воспользоваться функцией поиска по форуму? Вы вводите в поле поиска размер вашей панели 1024х600 и вводите. 1024x600 , 1024x600 , 1024x600 Или вы имеете в виду 600x1024? and this is what it looks like, but I thought there were also sensors on the side... well, great, that means less problems for the person Quote Link to comment Share on other sites More sharing options...
mugi Posted October 5, 2023 Author Share Posted October 5, 2023 40 minutes ago, Shephard said: then it may already look like something, with your permission, I would like to rest today, we will continue tomorrow, I hope you have time to get the result Thank you so much for your efforts Quote Link to comment Share on other sites More sharing options...
mugi Posted October 5, 2023 Author Share Posted October 5, 2023 40 minutes ago, JariKoi said: Why not use forum search function? You enter the size of your panel 1024x600 in the search field and enter. 1024x600 , 1024x600 , 1024x600 Or do you mean 600x1024? I did try that but couldn't find the one I was looking for Quote Link to comment Share on other sites More sharing options...
mugi Posted October 5, 2023 Author Share Posted October 5, 2023 33 minutes ago, Shephard said: and this is what it looks like, but I thought there were also sensors on the side... well, great, that means less problems for the person Looks cool Quote Link to comment Share on other sites More sharing options...
