ninjasushi2 Posted March 21, 2013 Posted March 21, 2013 I can't seem to find the file to uninstall AIDA 64 extreme anywhere. I've looked under control panel, using JVPowerTools16 2011, and even Uninstall MAX or wahtever the program is. My OSD menu random disappeared and won't reappear for some reason. So I tried to update and uninstall but to no avail. Updating doesn't help and there is no file to uninstall it. Any ideas? Edit: I just deleted all the files and reinstalled it; still no progress. Sensor Panel and Sensor Icons show just no OSD panel. Quote
Fiery Posted March 21, 2013 Posted March 21, 2013 If there's no uninstall shortcut in Control Panel, then I guess you deployed AIDA64 via its ZIP package. In that case you just need to remove the files and folders for AIDA64. For a full cleanup, start Registry Editor, and remove the complete AIDA64 folder under:HKEY_CURRENT_USER\Software\FinalWire Regards, Fiery Quote
