CPU - A10-5800k
Windows 7 SP1 ultimate x64
Aida64 version  2.85.2400
Hi, I see people having a few probs with a similar mobo, so thought I would show how mine is behaving or misbehaving as the case may be!
Mobo temp and CPU temps display fine but no Core temps or GPU Diode.
My 2 chassis fans display their speed OK but there is no read out from the CPU fan.
( I have one 4 wire fan plugged into CPU 1.)
I'll paste the read out of the display and the debug info.
If anything else is required, please let me know.
Cheers :)
Sensor Properties
Sensor Type    Nuvoton NCT6776F  (ISA 290h)
GPU Sensor Type    Diode  (ATI-Diode)
Motherboard Name    ASRock FM2A75 Pro4
Chassis Intrusion Detected    Yes
Temperatures
Motherboard    29 °C  (84 °F)
CPU    36 °C  (97 °F)
CPU #1 / Core #1    8 °C  (46 °F)
CPU #1 / Core #2    8 °C  (46 °F)
CPU #1 / Core #3    8 °C  (46 °F)
CPU #1 / Core #4    8 °C  (46 °F)
GPU Diode    3 °C  (37 °F)
KINGSTON SV300S37A120G    27 °C  (81 °F)
WDC WD10EZEX-00KUWA0    28 °C  (82 °F)
WDC WD5000AACS-00ZUB0    28 °C  (82 °F)
Cooling Fans
Chassis #1    1327 RPM
Chassis #2    1191 RPM
Voltage Values
CPU Core    1.336 V
CPU VDD    1.363 V
CPU VDDNB    1.244 V
+3.3 V    3.392 V
+5 V    5.112 V
+12 V    12.250 V
+5 V Standby    5.212 V
GPU Core    0.937 V
Current Values
CPU VDD    10.59 A
CPU VDDNB    4.47 A
Power Values
CPU Package    19.99 W
CPU VDD    14.43 W
CPU VDDNB    5.56 W
Debug Info F    1336 164 164 164 164
Debug Info T    30 36 128 / 255 40
Debug Info V    A7 E9 D4 D3 00 D4 00 (03)
Debug Info I    C1 C333
Motherboard ID      : 63-0100-000001-00101111-050312-Chipset$AS591190_BIOS DATE: 11/23/12 22:09:37 VER: 04.06.05
Motherboard Model   : ASRock FM2A75 Pro4
Motherboard Chipset : AMD A75, AMD K15.1
DMI MB Manufacturer : ASRock
DMI MB Product      : FM2A75 Pro4
DMI MB Version      :
DMI MB Serial       :
DMI SYS Manufacturer: To Be Filled By O.E.M.
DMI SYS Product     : To Be Filled By O.E.M.
DMI SYS Version     : To Be Filled By O.E.M.
DMI SYS Serial      : To Be Filled By O.E.M.
DMI BIOS Version    : P1.90
ITE 87xx Port           = 00h
ITE 87xx Device ID      = 0000h
ITE 87xx Version        = 00h
Winbond SuperIO Port           = 2Eh
Winbond SuperIO HWMonitor Port = 0290h
Winbond SuperIO Device ID      = C333h
Winbond Sensor ID A3/5C/reg$58 = A3 / 5C / C1
Fintek SuperIO Port           = 00h
Fintek SuperIO Device ID      = 0000h
LPC47 SuperIO Device ID      = FFFFh
------[ Nuvoton ISA Sensor Device at 0290 / Bank #0 ]------
0000  04 50 04 75  00 FF FF FF  FF FF FF FF  FF FF FF FF
0010  04 FF 00 00  00 00 FF FF  40 00 00 00  00 00 00 00
0020  A8 E8 D4 D4  00 D5 00 1D  FF FF FF DA  00 00 00 00
0030  00 00 00 00  00 00 00 00  00 00 00 FF  FF FF FF FF
0040  03 00 10 FF  FF 00 3F FF  2D FF FF FF  18 05 00 A3
0050  FF FF FF FF  FF FF FF FF  C1 FF FF FF  FF 00 00 FF
0060  CF FF FF FF  FF 01 00 FF  FF FF FF FF  FF FF FF FF
0070  00 0A 00 24  80 24 80 80  00 FF FF FF  FF FF FF FF
0080  FF 03 1F 0F  FF 3C 3C 3C  00 00 00 00  00 00 00 00
0090  0A 00 00 00  00 0A 0A 0A  0A AA EF 80  FF 40 46 C4
00A0  0E 01 00 00  FF 00 00 FF  00 00 80 66  66 06 00 01
00B0  00 00 00 00  00 00 2A 00  1C 00 00 34  28 80 C4 FF
00C0  01 00 00 00  00 00 00 00  00 0C 06 FF  FF FF FF FF
00D0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00E0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00F0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Reg$20 CPU Core:  r = 168,  r*0.016 = 2.69
Reg$21  CPU Aux:  r = 232,  r*0.016 = 3.71
Reg$22   +3.3 V:  r = 212,  r*0.016 = 3.39
Reg$23     +5 V:  r = 212,  r*0.016 = 3.39
Reg$24    +12 V:  r =   0,  r*0.016 = 0.00
Reg$25    -12 V:  r = 213,  r*0.016 = 3.41
Reg$26     -5 V:  r =   0,  r*0.016 = 0.00
------[ Nuvoton ISA Sensor Device at 0290 / Bank #1 ]------
0000  82 32 12 03  03 50 FF 60  FF 50 FF FF  00 FF FF FF
0010  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0020  00 19 23 2D  37 FF FF 8C  AA C8 E6 FF  FF FF FF FF
0030  FF 00 FF FF  00 7F FF FF  00 01 00 00  00 00 00 00
0040  FF FF FF FF  FF 30 05 FF  FF FF FF FF  FF FF 00 FF
0050  24 80 00 4B  00 50 00 FF  FF FF FF FF  FF FF FF FF
0060  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0070  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0080  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0090  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00A0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00B0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00C0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #2 ]------
0000  82 32 12 03  03 75 FF 60  FF 75 FF FF  00 FF FF FF
0020  00 28 32 3C  46 FF FF 8C  AA C8 E6 FF  FF FF FF FF
0040  FF FF FF FF  FF A4 00 FF  FF FF FF FF  FF FF 00 FF
0050  80 00 00 4B  00 50 00 FF  FF FF FF FF  FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #3 ]------
0000  03 00 00 0A  0A 01 01 3C  FF FF FF FF  00 FF FF FF
0030  FF 00 FF FF  00 3C FF FF  00 01 00 00  00 00 00 00
0050  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #4 ]------
0000  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0010  00 00 00 00  00 00 00 00  00 00 00 FF  FF FF FF FF
0020  FF FF FF 96  64 96 64 E1  96 FF FF FF  FF FF FF FF
0030  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0040  3F 00 03 FF  FF FF FF FF  FF FF FF FF  FF FF 00 FF
0050  00 13 FF FF  00 00 00 FF  00 DE 1E A1  09 FF FF FF
0060  FF 01 00 00  00 00 00 00  FF FF FF FF  FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #5 ]------
0000  FF FF 00 00  00 00 FF FF  FF FF FF FF  FF 00 00 FF
0020  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0040  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF 00 FF
0050  D7 00 00 FF  00 00 00 00  FF FF FF FF  FF FF FF FF
0060  00 00 00 00  00 00 07 00  01 FF FF FF  FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #6 ]------
0000  00 00 FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0020  FF 01 02 03  01 01 01 FF  00 00 00 1D  1D 1D 07 FF
0030  1F 18 FF 1F  FF 1F FF 1F  FF 1F 00 00  00 00 00 00
0040  00 00 00 00  02 02 02 FF  FF FF FF FF  FF FF 00 FF
0050  7F 7F 7F 7F  7F 7F 05 30  00 A4 00 A4  00 A4 00 A4
0070  7F 7F 50 4B  04 7F 7F 50  4B 04 7F 7F  50 4B 04 FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #7 ]------
0000  FF 10 02 00  00 00 00 00  00 00 00 00  00 00 00 00
0010  00 00 00 00  00 00 00 F8  80 F8 80 F8  80 F8 80 00
0020  28 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0030  00 00 00 FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
   0027  0150  0250  007D  007E  062B  062C  062D  0720
T:   29    36   128   255   255    29    29    29    40
------[ Hudson-2/3 PM2 at 0CD0 ]------
0000  06 1E F7 74  BF 05 00 00  00 00 00 00  00 00 FF FF
0010  00 00 00 00  00 00 00 00  00 00 00 00  00 00 FF FF
0020  00 00 00 00  00 00 00 00  00 00 00 00  00 00 FF FF
0030  00 00 00 00  00 00 00 00  00 00 00 00  00 00 FF FF
0040  00 00 00 00  00 00 00 00  00 00 00 00  00 00 FF FF
0060  1F 00 00 00  00 00 03 00  00 3D 02 03  00 00 FF FF
0070  03 00 00 FF  FF 03 00 00  FF FF 03 00  00 FF FF FF
0090  00 55 01 00  00 00 00 00  00 00 00 00  00 00 00 00
00A0  00 00 00 00  00 00 00 00  00 FF FF 00  00 00 00 00
00B0  00 FF 55 55  FF 00 00 FF  00 00 00 00  00 00 00 00
00C0  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
00D0  00 00 00 00  00 00 00 00  FF FF FF FF  FF 00 FF 00
00E0  00 00 00 00  00 00 00 00  00 00 91 1F  01 00 00 02
00F0  19 0A 02 05  C8 20 80 00  04 06 00 55  08 08 00 02
Reg$59VIN0:  r = $FFFF,  r*0.000046 = 3.0146
Reg$5DVIN1:  r = $FFFF,  r*0.000046 = 3.0146
Reg$61VIN2:  r = $0000,  r*0.000046 = 0.0000
Reg$65VIN3:  r = $0300,  r*0.000046 = 0.0353
Reg$69VIN4:  r = $023D,  r*0.000046 = 0.0264
Reg$6DVIN5:  r = $FF00,  r*0.000046 = 3.0029
Reg$71VIN6:  r = $0000,  r*0.000046 = 0.0000
Reg$75VIN7:  r = $0003,  r*0.000046 = 0.0001
------[ Hudson-2/3 PM at 0CD6 ]------
0000  0E 00 4F 4A  00 04 00 02  34 05 04 02  06 21 43 55
0010  FF 0F 00 00  FF 0F 00 00  00 00 00 00  00 00 00 00
0020  00 00 D1 FE  01 00 D8 FE  27 0B 80 00  01 0B 00 00
0030  00 00 00 00  07 00 C0 FE  0C 00 00 00  00 00 00 00
0040  00 00 00 00  00 00 00 00  F1 00 C0 FE  03 00 00 00
0050  01 00 D0 FE  D0 00 00 97  01 FF 15 66  00 05 00 01
0060  00 08 04 08  08 08 10 08  20 08 B2 00  00 FE BA 00
0070  00 00 00 00  17 00 00 4C  FF FF 00 00  FF FF E0 81
0080  00 18 26 28  00 00 00 00  00 00 00 00  9E 00 80 00
0090  02 05 02 0B  0A 00 10 00  00 10 00 01  00 00 00 00
00A0  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
00B0  00 00 8A 00  80 00 05 05  88 00 08 44  F2 00 53 C0
00C0  F9 07 58 40  2C 02 00 00  0C 40 38 00  F9 FF FF FF
00D0  00 F4 38 BF  00 00 20 00  15 00 91 00  01 00 10 03
00E0  D8 0C 00 00  00 00 00 02  00 00 00 01  03 17 00 CF
00F0  9C 73 07 00  00 00 00 21  6C 07 00 00  00 00 00 00
_TZ_.THM0._TMP             :
_TZ_.THM1._TMP             :
_TZ_.THR0._TMP             :
_TZ_.THR1._TMP             :
_TZ_.TZ00._TMP             :
_TZ_.TZ01._TMP             :
_TZ_.RTMP                  :
_TZ_.RFAN                  :
_TZ_.RFAN(0)               :
_TZ_.RFAN(1)               :
_SB_.ATKD._HID             :
_SB_.ATKD.TMPR             :
_SB_.PCI0.LPC0.EC0_.CCTV   :
_SB_.PCI0.LPC0.EC0_.LRPM   :
_SB_.PCI0.LPC0.EC0_.HRPM   :
_SB_.PCI0.SBRG.EC0_.ECPU   :
_SB_.PCI0.SBRG.EC0_.TACH(0):
_SB_.PCI0.SBRG.EC0_.TACH(1):
_SB_.PCI0.SBRG.EC0_.TAH0   :
_SB_.PCI0.SBRG.EC0_.TAH1   :
_SB_.PCI0.SBRG.EC0_.ST00   :
_SB_.PCI0.SBRG.EC0_.SC01   :
_SB_.PCI0.SBRG.EC0_.SC02   :
_SB_.PCI0.SBRG.EC0_.SC03   :
_SB_.PCI0.SBRG.EC0_.SC04   :
_SB_.PCI0.SBRG.EC0_.SC05   :
_SB_.PCI0.SBRG.EC0_.SC06   :
_SB_.PCI0.PIB_.EC0_.TCRT   :
_SB_.PCI0.SBRG.EC0_.CTPM   :
_SB_.PCI0.SBRG.EC__.CPUT   :
_SB_.PCI0.SBRG.EC__.SYST   :
_SB_.PCI0.LPC_.EC0_.CTMP   :
_SB_.PCI0.LPCB.EC0_.CTMP   :
_SB_.PCI0.LPC_.EC0_.TMP1   :
_SB_.PCI0.LPC_.EC0_.TMP2   :
_SB_.PCI0.LPC_.EC0_.TMPI   :
_SB_.PCI0.LPC_.EC0_.TMPV   :
_SB_.PCI0.LPCB.EC0_.A1TP   :
_SB_.PCI0.LPCB.EC0_.A2TP   :
_SB_.PCI0.LPCB.EC0_.FAN0   :
_SB_.PCI0.LPCB.EC__.TS1R   :
_SB_.PCI0.LPCB.EC__.TS2R   :
_SB_.PCI0.LPCB.EC__.TS3R   :
_SB_.PCI0.LPCB.EC__.F1FL   :
_SB_.PCI0.LPCB.EC__.F1FH   :
_SB_.PCI0.LPCB.EC__.F2FL   :
_SB_.PCI0.LPCB.EC__.F2FH   :
_SB_.PCI0.LPC_.H8EC.RTMP   :
_SB_.PCI0.LPC_.H8EC.LTMP   :
_SB_.PCI0.LPC_.H8EC.MTMP   :
_SB_.PCI0.LPC_.H8EC.GTMP   :
_SB_.PCI0.LPCB.H8EC.CTMP   :
_SB_.PCI0.LPCB.H8EC.DTMP   :
_SB_.PCI0.LPCB.H8EC.GTMP   :
_SB_.PCI0.LPCB.H8EC.ITMP   :
_SB_.PCI0.LPCB.H8EC.MTMP   :
_SB_.PCI0.LPCB.H8EC.STMP   :
_SB_.PCI0.LPCB.H8EC.PFAN   :
_SB_.PCI0.LPCB.EC0_.OTPC   :
_SB_.PCI0.LPCB.EC0_.VGAT   :
_SB_.PCI0.LPCB.EC0_.CHPT   :
_SB_.PCI0.LPCB.EC0_.CPUT   :
_SB_.PCI0.LPCB.EC0_.SYST   :
_SB_.PCI0.LPCB.EC0_.DTS1   :
_SB_.PCI0.LPCB.EC0_.DTS2   :
_SB_.PCI0.LPCB.EC0_.DIMM   :
_SB_.PCI0.LPCB.EC0_.FANH   :
_SB_.PCI0.LPCB.EC0_.FANL   :
_SB_.PCI0.LPCB.EC0_.CUTP   :
_SB_.PCI0.LPCB.EC0_.PHTP   :
_SB_.PCI0.LPCB.EC0_.DIMT   :
_SB_.PCI0.LPCB.EC0_.INLE   :
_SB_.PCI0.LPCB.EC0_.PANT   :
_SB_.PCI0.LPCB.EC0_.F0RM   :
_SB_.PCI0.LPCB.EC0_.F0DT   :
_SB_.PCI0.LPCB.EC0_.F1RM   :
_SB_.PCI0.LPCB.EC0_.F1DT   :
------[ SMBus #0 ]------
SMBus Type  : Intel / VIA / ServerWorks / SMSC / ATI
SMBus Port  : 0B00
Can Have SPD: Yes
Scan Type   : Full
------[ SMBus Device B00-D52 ]------
  0000  92 11 0B 02 03 19 00 09 03 11 01 08 0A 00 FC 00  ................
  0010  69 78 69 30 69 11 18 81 00 05 3C 3C 00 F0 83 05  ixi0i.....<<....
  0020  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0030  00 00 00 00 00 00 00 00 00 00 00 00 0F 11 01 01  ................
  0040  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0050  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0060  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0070  00 00 00 00 00 04 CD 00 00 00 00 00 00 00 4F 6C  ..............Ol
  0080  46 33 2D 31 34 39 30 30 43 4C 39 2D 34 47 42 53  F3-14900CL9-4GBS
  0090  52 00 00 00 04 CD 00 00 00 00 00 00 00 00 00 00  R...............
  00A0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00B0  0C 4A 3F 13 01 08 03 1C 11 2A 09 4A 20 00 3B 4A  .J?......*.J .;J
  00C0  52 77 10 EC 3A 3F 00 00 05 3C 28 00 C8 3C 00 00  Rw..:?...<(..<..
  00D0  10 00 00 CA F2 F2 AB FE 00 00 00 00 2A 0A 57 20  ............*.W
  00E0  00 46 57 61 8C 11 15 6F 49 00 D7 05 46 2E 00 E9  .FWa...oI...F...
  00F0  46 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00  F...............
------[ SMBus Device B00-D53 ]------
------[ Chips Found ]------
B00-D52: SPD
B00-D53: SPD
Thank you for the data.  Your motherboard uses the usual ASRock fan mux logic, so only one of the CPU fans can be monitored by AIDA64.  If you connect the fan to the other CPU fan connector, AIDA64 will show the RPM for it.
As for core temperatures and GPU diode temperature, they are quite low, and it is due to the common hardware issue of modern AMD processors (e.g. FX, Llano, Trinity, Richland).  They measure unrealistically low temperatures at idle, but the measurements get much closer to real when the system is under heavy load.  Unfortunately this is a hardware issue that cannot be fixed from software.
I paralleled the speed tacho lead across from cpu fan 1 connector to cpu fan 2 connector.
This allows Aida to read speed OK and still retain the PWM control from the cpu 1 connector...
Thanks!
