pbcopter Posted April 25, 2013 Posted April 25, 2013 After the upgrade today to build 2430, the gauges I had in my sensor panel were reduced to just icons. Going back to build 2419 returns the panel to normal. Any suggestions? I'm sorry, I should have posted this in the bug report area. Quote
pbcopter Posted April 26, 2013 Author Posted April 26, 2013 Hi Fiery I followed the instructions you gave Xyzzy Frobozz, using the downloaded zip file for build 2430 and everything is normal again. I had the same corrupted .dll file. Thanks Paul Quote
Fiery Posted April 26, 2013 Posted April 26, 2013 Thank you for your message, I'm glad you managed to resolve it. We'll fine-tune the DLL handling at automatic updates from the next AIDA64 beta release, to make sure such issues wouldn't happen again.Regards, Fiery Quote
