CastusTroy Posted December 28, 2023 Posted December 28, 2023 So I picked up a display for $120 and paid $60 for aida64 just for nothing to work, been going on 3 days trying to get the drivers to work. I have tried every forum every YouTube video every driver I could download, even using zadig. No matter what i do I get the same usb device 1908-0102 not found. Ready to throw this thing in the garbage and just yank my old display from my 2010 pc out that uses a temp and fan speed screen. Don't gotta install or download shit. Any help would be much appreciated. Quote
Fiery Posted December 29, 2023 Posted December 29, 2023 On 12/28/2023 at 7:05 AM, CastusTroy said: So I picked up a display for $120 and paid $60 for aida64 just for nothing to work, been going on 3 days trying to get the drivers to work. I have tried every forum every YouTube video every driver I could download, even using zadig. No matter what i do I get the same usb device 1908-0102 not found. Ready to throw this thing in the garbage and just yank my old display from my 2010 pc out that uses a temp and fan speed screen. Don't gotta install or download shit. Any help would be much appreciated. In AIDA64 please press Ctrl+Alt+D --> System Debug --> USB Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery Quote
Fiery Posted December 30, 2023 Posted December 30, 2023 5 minutes ago, erdallotus said: usbdump.txt 7.82 kB · 0 downloads Thank you! Your device seems to require the SmartCool LCD module and not the AX206 LCD module. Quote
Casimiro Bocayo Posted February 9, 2024 Posted February 9, 2024 Hello, I do have the same problem but the device was working properly for about 3 months now, I just re-routed the cable and it works yesterday but now it says "Error: USB Device 1908-0102 not found. I even tried other USB-C cables but no luck. usbdump.txt Quote
Fiery Posted February 9, 2024 Posted February 9, 2024 5 hours ago, Casimiro Bocayo said: Hello, I do have the same problem but the device was working properly for about 3 months now, I just re-routed the cable and it works yesterday but now it says "Error: USB Device 1908-0102 not found. I even tried other USB-C cables but no luck. usbdump.txt 18.47 kB · 0 downloads There's no AX206 device in that dump. I don't think your computer recognizes your display using the current cable. Quote
BBMSX Posted November 22, 2024 Posted November 22, 2024 I am trying to get this display to work, it is not able (to detect it as a display). I am looking for the drivers, but it is no good (Samsung) What can I do (my module is AX206 LCD FOR AIDA64 BUSINESS appears with the name USB - display in the device manager (it is a LAPTOP) It is for a project. Quote
Fiery Posted November 24, 2024 Posted November 24, 2024 On 11/23/2024 at 12:49 AM, BBMSX said: I am trying to get this display to work, it is not able (to detect it as a display). I am looking for the drivers, but it is no good (Samsung) What can I do (my module is AX206 LCD FOR AIDA64 BUSINESS appears with the name USB - display in the device manager (it is a LAPTOP) It is for a project. In AIDA64 please press Ctrl+Alt+D --> System Debug --> USB Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery Quote
erenilson Posted January 2, 2025 Posted January 2, 2025 o meu esta dando esse erro alguem consegue ajudar usbdump.txt Quote
Fiery Posted January 8, 2025 Posted January 8, 2025 On 1/2/2025 at 4:32 AM, erenilson said: o meu esta dando esse erro alguem consegue ajudar usbdump.txt 16.63 kB · 0 downloads You don't have an AX206 LCD display. What you've got is a 3.5-inch Turing (Turzx) Smart Screen which is not yet supported by AIDA64. We're currently working on implementing support for all Turing displays available on the market. Quote
Mehmet Kral Posted January 18, 2025 Posted January 18, 2025 I am also waiting I already have a g19 and it is very old. I bought a turing screen that I will change and I am waiting Quote
Fiery Posted February 4, 2025 Posted February 4, 2025 On 1/2/2025 at 4:32 AM, erenilson said: o meu esta dando esse erro alguem consegue ajudar We've implemented support for Turing (Turzx) LCD devices. Let's continue discussing Turing displays in their own topic: Quote
tomasman Posted March 2, 2025 Posted March 2, 2025 Здравствуйте! 3.5 SmartCool определяется как USB Display. Не могу подключить к AIDA64. usbdump.txt Quote
Fiery Posted March 16, 2025 Posted March 16, 2025 On 3/2/2025 at 7:17 PM, tomasman said: Здравствуйте! 3.5 SmartCool определяется как USB Display. Не могу подключить к AIDA64. usbdump.txt 4.43 kB · 2 downloads Yours is an AX206 LCD, so you need to use the AX206 LCD module of AIDA64. I also recommend you to upgrade to the latest version of AIDA64: https://www.aida64.com/downloads/latesta64xe Quote
