vlado015 Posted February 21, 2024 Posted February 21, 2024 Helloo, I install aida64 extreme sensor panel but don't see the gpu util. gpu clock gpu mem clock gpu vram on my asus tuf oc rtx 4070 ti super https://ibb.co/PspdTyf Quote
Fiery Posted February 21, 2024 Posted February 21, 2024 11 hours ago, vlado015 said: Helloo, I install aida64 extreme sensor panel but don't see the gpu util. gpu clock gpu mem clock gpu vram on my asus tuf oc rtx 4070 ti super https://ibb.co/PspdTyf Make sure to upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. Quote
vlado015 Posted February 23, 2024 Author Posted February 23, 2024 Heloo, I upgrade to 7.00.6751 beta, all is okey, only missing gpu temp see pic tnx very much Quote
rinaldop Posted February 23, 2024 Posted February 23, 2024 4 hours ago, vlado015 said: Heloo, I upgrade to 7.00.6751 beta, all is okey, only missing gpu temp see pic tnx very much You are seeing the word TRIAL because you have not paid for a full function license. 1 Quote
2Realist4U Posted January 1 Posted January 1 I'm having an issue with the 4070 Ti; it's not showing the fan speeds. Any help would be appreciated. Quote
Fiery Posted January 1 Posted January 1 6 hours ago, 2Realist4U said: I'm having an issue with the 4070 Ti; it's not showing the fan speeds. Any help would be appreciated. Make sure to upgrade to the latest version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xe After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Quote
2Realist4U Posted January 2 Posted January 2 17 hours ago, Fiery said: Make sure to upgrade to the latest version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xe After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Thanks so much Fiery. Ends up, that my GPU rarely turns the fan on -- even at high temps. So it was my bad. Thanks again. Quote
