rinaldop Posted March 31, 2024 Posted March 31, 2024 I am running Aida64 v7.20.6811 Beta and my hard drive temperature used to be reported but I no longer see that listed. Motherboard Name Asus ROG Strix B650E-F Gaming WiFi Driver Description WD_BLACK SN850X 2000GB I am running the latest driver What dump do you want to troubleshoot it? Quote
Fiery Posted April 6, 2024 Posted April 6, 2024 On 3/31/2024 at 10:41 PM, rinaldop said: I am running Aida64 v7.20.6811 Beta and my hard drive temperature used to be reported but I no longer see that listed. Motherboard Name Asus ROG Strix B650E-F Gaming WiFi Driver Description WD_BLACK SN850X 2000GB I am running the latest driver What dump do you want to troubleshoot it? Expand In AIDA64 please press Ctrl+Alt+D --> Disk Debug --> RAID Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Also, in AIDA64 press Ctrl+Alt+D --> Disk Debug --> SMART Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery Quote
rinaldop Posted April 7, 2024 Author Posted April 7, 2024 On 4/6/2024 at 10:40 AM, Fiery said: In AIDA64 please press Ctrl+Alt+D --> Disk Debug --> RAID Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Also, in AIDA64 press Ctrl+Alt+D --> Disk Debug --> SMART Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery Expand Here are both dump text files in one archive. DUMP.zipFetching info... Quote
Fiery Posted April 7, 2024 Posted April 7, 2024 On 4/7/2024 at 6:14 AM, rinaldop said: Here are both dump text files in one archive. Expand Thank you! In that dump temperature was properly measured for your SSD. Are you sure it's not listed properly on the Computer / Sensor and Storage / SMART pages? Quote
rinaldop Posted April 7, 2024 Author Posted April 7, 2024 On 4/7/2024 at 9:45 AM, Fiery said: Thank you! In that dump temperature was properly measured for your SSD. Are you sure it's not listed properly on the Computer / Sensor and Storage / SMART pages? Expand I do see it on Storage / SMART but not on Computer / Sensor Quote
Solution Fiery Posted April 8, 2024 Solution Posted April 8, 2024 On 4/7/2024 at 6:03 PM, rinaldop said: I do see it on Storage / SMART but not on Computer / Sensor Expand Do you have the option called Enable disk temperature measurement checked (enabled) in AIDA64 / Preferences / Hardware Monitoring? Quote
rinaldop Posted April 8, 2024 Author Posted April 8, 2024 On 4/8/2024 at 7:13 AM, Fiery said: Do you have the option called Enable disk temperature measurement checked (enabled) in AIDA64 / Preferences / Hardware Monitoring? Expand Ah, no it was NOT checked. It must have gotten unchecked during some update, or is that new? Well, it works now, thanks! Quote
Fiery Posted April 8, 2024 Posted April 8, 2024 On 4/8/2024 at 3:31 PM, rinaldop said: Ah, no it was NOT checked. It must have gotten unchecked during some update, or is that new? Well, it works now, thanks! Expand It's enabled by default, so you must have unchecked at some point Quote
rinaldop Posted April 8, 2024 Author Posted April 8, 2024 On 4/8/2024 at 6:24 PM, Fiery said: It's enabled by default, so you must have unchecked at some point Expand I do not see why I would do that but perhaps I miss clicked one day. It does work now. Quote
