Matt Posted July 10, 2013 Posted July 10, 2013 I've got a SSD as my primary HDD and some personal data on a conventional HDD. It seems that AIDA64 prevents the second HDD from going into standby. Can anybody confirm this? It's important for me, because that HDD is the loudest part in my PC My second point (I don't want to open two threads): Is it possible, not only to send data to RTSS, but to receive data (the FPS to be specific) like MSI Afterburner is doing it? I'm using the G15 LCD plugin and the frames per second would be the last missing value Quote
Fiery Posted July 10, 2013 Posted July 10, 2013 1) Reading SMART values (incl. drive temperature) out of HDDs and SSDs make them keep going to sleep. This is a firmware limitation that is still not addressed after so many years What you can do is increase the Disk temperature polling frequency value in AIDA64 / main menu / File / Preferences / Hardware Monitoring. 2) Fraps is the only external software that AIDA64 supports to import values from. Regards, Fiery Quote
Matt Posted July 10, 2013 Author Posted July 10, 2013 Both solutions are working! HDD is going to sleep again! Max. polling frequency is 1 hour, thats ok, definitely better than before. Thank you very much!! Quote
AdinGira Posted January 13, 2014 Posted January 13, 2014 Matt's situation is similar to mine. However, I am not satisfied with variants hourly awakening hard drive to determine temperature. How to completely turn off the hard drive temperature monitoring in AIDA64? Quote
Fiery Posted January 13, 2014 Posted January 13, 2014 Matt's situation is similar to mine. However, I am not satisfied with variants hourly awakening hard drive to determine temperature. How to completely turn off the hard drive temperature monitoring in AIDA64? We've added a new option (Enable disk temperature measurement) to the AIDA64 Preferences / Hardware Monitoring page. Make sure to upgrade to the latest beta version of AIDA64 Extreme available at: http://www.aida64.com/downloads/aida64extremebuild2746bhv2s4qfjlzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know if it suits your needs Quote
AdinGira Posted February 14, 2014 Posted February 14, 2014 Thank you, Fiery, it was to be! One more wish — to allow values ​​less than 1 for "Graph step" into LCD Items / Item type: Graph. This is useful, since for one update, the schedule is shifted by more than one pixel. Quote
Fiery Posted February 16, 2014 Posted February 16, 2014 Shifting only one pixel would make the graph look quite odd. We've done test runs with it, and the best visual feedback is by using 2-pixel step rate. Quote
