Tony Lou Posted April 20, 2024 Posted April 20, 2024 my problem issue in details where CPU Fan is not mentioned or shown in the Cooling Fans and Fan Speeds section Quote
Fiery Posted April 20, 2024 Posted April 20, 2024 20 minutes ago, Tony Lou said: my problem issue in details where CPU Fan is not mentioned or shown in the Cooling Fans and Fan Speeds section What version of AIDA64 are you using? Quote
Fiery Posted April 20, 2024 Posted April 20, 2024 6 hours ago, Tony Lou said: v7.20.6802 In AIDA64 please press Ctrl+Alt+D --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery Quote
Tony Lou Posted April 20, 2024 Author Posted April 20, 2024 1 hour ago, Fiery said: In AIDA64 please press Ctrl+Alt+D --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery here you go isasensordump.txt Quote
Fiery Posted April 20, 2024 Posted April 20, 2024 45 minutes ago, Tony Lou said: here you go isasensordump.txt 40.6 kB · 1 download Thank you! Everything seems to be fine there. I suppose your CPU fan was not shown in the list of the available sensor items because the CPU fan wasn't spinning at that time. Quote
Tony Lou Posted April 21, 2024 Author Posted April 21, 2024 On 4/20/2024 at 9:25 PM, Fiery said: Thank you! Everything seems to be fine there. I suppose your CPU fan was not shown in the list of the available sensor items because the CPU fan wasn't spinning at that time. Quote
