EVGA GTX 770 SC w/ACX - Fan speed in % showing wrong value
Hello!
I just installed my new GPU EVGA GTX 770 SC/wACX replacing my old ASUS GTX 470. Now I have noticed that AIDA shows GPU fan speed in rpm properly but scales it to wrong percentage value. While idling in 2d desktop fan speed % should show 41%. Instead AIDA shows 27% value.
With GTX 470 %-value was OK. All other sensor/measured values are OK.
Make sure to upgrade to the latest beta version of AIDA64 Extreme Edition available at:
http://www.aida64.com/downloads/aida64extremebuild2546y3mbp1kvdjzip
If it doesn't help, then please right-click on the bottom status bar of AIDA64 main window --> Video Debug --> nVIDIA GPU Registers.  Copy-paste the full results into this topic. Also, right-click on the bottom status bar of AIDA64 main window --> Video Debug --> nVIDIA SMBus Dump.  Copy-paste the full results into this topic.
I installed the latest beta version and rebooted but unfortunately fan speed %-value is still wrong. When idling at min. speed fan speed is 1350 rpm which is 41% from the max. speed.
Here is the nVidia GPU register data:
------[ AIDA64 v3.00.2546 Beta ]------
------[ Microsoft Windows 7 Professional 6.1.7601.18113 Service Pack 1 (64-bit) ]------
------[ Video Adapters ]------
EVGA e-GeForce GTX 770 [10DE-1184 / 3842-2774]
------[ Video Driver ]------
nvapi.dll: 9.18.13.2049
nvd3dumx||9.18.13.2049|||nvwgf2umx||9.18.13.2049|||nvwgf2umx||9.18.13.2049|||nvd3dum||9.18.13.2049 - nVIDIA ForceWare 320.49|||nvwgf2um||9.18.13.2049|||nvwgf2um||9.18.13.2049
------[ nVIDIA GPU #1 @ mem F6000000 ]------
GPU Clocks   = 135 / 0 / 0 MHz
Memory Clock = 324 MHz
GPU    Base Clock = 27000 kHz
Shader Base Clock = 27000 kHz
Memory Base Clock = 27000 kHz
nvidia-000000 = 0E4040A2
nvidia-001218 = 00000000
nvidia-001538 = 800003FF
nvidia-001704 = 8007FFC1
nvidia-001714 = C007FFC2
nvidia-00E114 = 00000001
nvidia-00E118 = 00000000
nvidia-00E11C = 00000001
nvidia-00E120 = 00000000
nvidia-00E728 = 0021002E
nvidia-00E820 = 01030005
nvidia-00E8A0 = 02010000
nvidia-020008 = 00003589
nvidia-020014 = 05E003AA
nvidia-0200C4 = 000003E8
nvidia-0200C8 = 0000010D
nvidia-0200D8 = 060003E8
nvidia-0200DC = 0000010D
nvidia-020340 = 00000360
nvidia-020344 = 00000000
nvidia-020348 = 00000000
nvidia-020400 = 00000020
nvidia-022430 = 00000004
nvidia-022434 = 00000002
nvidia-022438 = 00000004
nvidia-02243C = 00000004
nvidia-022440 = 00000004
nvidia-022540 = 00000000
nvidia-022544 = 00000000
nvidia-022548 = 00000000
nvidia-022550 = 00000000
nvidia-022554 = 00000000
nvidia-088000 = 118410DE
nvidia-08A000 = 0E0A10DE
nvidia-100714 = 00000504
nvidia-101000 = 8040509E
nvidia-10100C = 8E013010
nvidia-10F290 = 040E140A
nvidia-10F294 = 2C310289
nvidia-10F590 = 03000204
nvidia-120070 = 00000001
nvidia-120074 = 00000004
nvidia-120078 = 00000004
nvidia-17E924 = E3000EFF
nvidia-300000 = EB7AAA55
nvidia-310000 = 872E4367
nvidia-700000 = 00000000
nvidia-7E0000 = 0000BEEF
------[ nVIDIA GPU #1 / ForceWare Properties ]------
Memory Type          = 8 (GDDR5)
Memory Bank Count    = 1
Memory Bus Width     = 256-bit
GPU / MC / VE Load   = 8 / 4 / 0
VPE Count            = 0
Shader Pipe Count    = 4
Shader SubPipe Count = 8
Total SP Count       = <unknown>
Total TPC Count      = 0
Total SM Count       = <unknown>
Core Count           = 1536
Partition Count      = 4 (mask: 0000000F)
Fan RPM              = 1380 RPM
Core Voltage         = 862 mV
Current Pstate       = 8
Ventura State        = 0 (unsupported)
Physical Frame Buffer Size = 2097152 KB
Virtual  Frame Buffer Size = 2097152 KB
Total / Free Video Memory  = 2097152 KB / 1976520 KB
------[ nVIDIA GPU #1 / ForceWare Clocks (old) ]------
Perf. Levels   = 4
Active Profile = 0
curr-core/shader/mem-0 = 405 MHz / 0 MHz / 324 MHz [Active]
curr-core/shader/mem-1 = 540 MHz / 0 MHz / 810 MHz
curr-core/shader/mem-2 = 540 MHz / 0 MHz / 3505 MHz
curr-core/shader/mem-3 = 540 MHz / 0 MHz / 3505 MHz
orig-core/shader/mem-0 = 405 MHz / 0 MHz / 324 MHz [Active]
orig-core/shader/mem-1 = 540 MHz / 0 MHz / 810 MHz
orig-core/shader/mem-2 = 540 MHz / 0 MHz / 3505 MHz
orig-core/shader/mem-3 = 540 MHz / 0 MHz / 3505 MHz
------[ nVIDIA GPU #1 / ForceWare Clocks (new) ]------
Perf. Levels   = 1
Active Profile = 255
curr-core/mem-0 = 135 MHz / 324 MHz
orig-core/boost/mem-0 = 1110 MHz / 1163 MHz / 3505 MHz
------[ nVIDIA GPU #1 / BIOS Info ]------
BIOS Version   = 80.04.B4.00.70
Signon Message = GK104 P2005 SKU 0000 VGA BIOS
Bootup Core Clock   = 2952792 MHz
Bootup Shader Clock = 1095320 MHz
Bootup Mem Clock    =    0 MHz
Ref. Clock 4000 =      0 kHz =   0 MHz *4
Ref. Clock 4008 =      0 kHz =   0 MHz *4 [Memory]
Ref. Clock 4010 =      0 kHz =   0 MHz *4
Ref. Clock 4018 =      0 kHz =   0 MHz *4
Ref. Clock 4020 =      0 kHz =   0 MHz *4 [shader]
Ref. Clock 4028 =      0 kHz =   0 MHz *4 [GPU]
Ref. Clock 4030 =      0 kHz =   0 MHz *4
Ref. Clock 4038 =      0 kHz =   0 MHz *4
Core Clock     =    0 MHz
Shader Clock   =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Core Voltage   = 0,00 V
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Diode Gain Mul        = 0
Diode Gain Div        = 0
Diode Offset Mul      = 0
Diode Offset Div      = 0
Diode Offset Bin Mul  = 0
Diode Offset Bin Div  = 1
Temp Compensation Mul = 0
Temp Compensation Div = 1
Max Div               = 0
Measured Temp Threshold (Raw)   = 0
Measured Temp Threshold (Int)   = 0 Celsius
Measured Temp Threshold (Float) = 0 Celsius
BIOS Temp Threshold             = 125 Celsius
Measured Diode Temp (Raw)       = 0
Measured Diode Temp (Int)       = 0 Celsius
Measured Diode Temp (Float)     = 0 Celsius
Diode Temp by ForceWare         = 33 Celsius
------[ NVAPI GPU Handles ]------
GPU Count = 1
GPU #1 = 00000100
------[ nVIDIA GPU #1 / Thermal Settings ]------
Sensor Count = 1
Sensor #0 / Controller   = GPU Internal
Sensor #0 / Target       = GPU Core
Sensor #0 / Current Temp = 33 Celsius
And here is the nVidia SMBus dump:
------[ nVIDIA GPU #1 / B00-CR1F = 00 ]------
------[ nVIDIA GPU #1 / B00-CR49 = 00 ]------
------[ nVIDIA GPU #1 / B01-CR1F = 00 ]------
------[ nVIDIA GPU #1 / B01-CR49 = 00 ]------
------[ nVIDIA GPU #1 / B02-CR1F = 00 ]------
------[ nVIDIA GPU #1 / B02-CR49 = 00 ]------
------[ nVIDIA GPU #1 / B03-CR1F = 00 ]------
------[ nVIDIA GPU #1 / B03-CR49 = 00 ]------
------[ nVIDIA SMBus Device GPU #1 / B03-D40 ]------
  0000  78 02 2F 00 2F 00 2F 7F 7F 7F 7F 7F 7F 00 7F 00  x./././..
  0010  27 23 FF FF FF FF FF FF FF FF FF F8 FF FF 54 32  '#............T2
  0020  78 02 2F 00 2F 00 2F 7F 7F 7F 7F 7F 7F 00 7F 00  x./././..
  0030  27 23 FF FF FF FF FF FF FF FF FF F8 FF FF 54 32  '#............T2
  0040  78 02 2F 00 2F 00 2F 7F 7F 7F 7F 7F 7F 00 7F 00  x./././..
  0050  27 23 FF FF FF FF FF FF FF FF FF F8 FF FF 54 32  '#............T2
  0060  78 02 2F 00 2F 00 2F 7F 7F 7F 7F 7F 7F 00 7F 00  x./././..
  0070  27 23 FF FF FF FF FF FF FF FF FF F8 FF FF 54 32  '#............T2
  0080  78 02 2F 00 2F 00 2F 7F 7F 7F 7F 7F 7F 00 7F 00  x./././..
  0090  27 23 FF FF FF FF FF FF FF FF FF F8 FF FF 54 32  '#............T2
  00A0  78 02 2F 00 2F 00 2F 7F 7F 7F 7F 7F 7F 00 7F 00  x./././..
  00B0  27 23 FF FF FF FF FF FF FF FF FF F8 FF FF 54 32  '#............T2
  00C0  78 02 2F 00 2F 00 2F 7F 7F 7F 7F 7F 7F 00 7F 00  x./././..
  00D0  27 23 FF FF FF FF FF FF FF FF FF F8 FF FF 54 32  '#............T2
  00E0  78 02 2F 00 2F 00 2F 7F 7F 7F 7F 7F 7F 00 7F 00  x./././..
  00F0  27 23 FF FF FF FF FF FF FF FF FF F8 FF FF 54 32  '#............T2
  0000  0778 6803 302F 7800 902F 0001 882F F87F F87F F87F F87F F87F F87F 0000 FE7F 0700
  0010  1027 2823 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF F8F8 FFFF FFFF 4954 2032
  0020  0778 0003 382F 6000 902F E800 882F F87F F87F F87F F87F F87F F87F 0000 FE7F 0700
  0030  1027 2823 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF F8F8 FFFF FFFF 4954 2032
  0040  0778 B802 382F 5800 902F E000 882F F87F F87F F87F F87F F87F F87F 0000 FE7F 0600
  0050  1027 2823 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF F8F8 FFFF FFFF 4954 2032
  0060  0778 9002 382F 5000 902F E000 882F F87F F87F F87F F87F F87F F87F 0000 FE7F 0700
  0070  1027 2823 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF F8F8 FFFF FFFF 4954 2032
  0080  0778 8002 382F 5000 902F D800 882F F87F F87F F87F F87F F87F F87F 0000 FE7F 0700
  0090  1027 2823 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF F8F8 FFFF FFFF 4954 2032
  00A0  0778 C002 382F 5000 902F E800 882F F87F F87F F87F F87F F87F F87F 0000 FE7F 0600
  00B0  1027 2823 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF F8F8 FFFF FFFF 4954 2032
  00C0  0778 9802 382F 4800 902F E000 882F F87F F87F F87F F87F F87F F87F 0000 FE7F 0700
  00D0  1027 2823 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF F8F8 FFFF FFFF 4954 2032
  00E0  0778 8802 382F 4800 902F D800 882F F87F F87F F87F F87F F87F F87F 0000 FE7F 0700
  00F0  1027 2823 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF F8F8 FFFF FFFF 4954 2032
------[ nVIDIA GPU #1 / B04-CR1F = 00 ]------
------[ nVIDIA GPU #1 / B04-CR49 = 00 ]------
------[ Chips Found ]------
GPU1-B03-D40: ***** Unknown Device *****
Total   :    3.7 sec
GPU1-B00:    0.8 sec
GPU1-B01:    0.2 sec
GPU1-B02:    0.2 sec
GPU1-B03:    2.0 sec
GPU1-B04:    0.5 sec
Thank you for the dumps.  Please check it with GPU-Z 0.7.2 as well, and let us know if it shows similar value to AIDA64 or not.
