Tony Lou Posted May 7, 2024 Posted May 7, 2024 can you help me The problem I am having is my Fans for the CPU are not showing up in the Modify iterm list is not mentioned or shown in the Cooling Fans and Fan Speeds section my Version of AIDA64 Is v7.20.6802 so i send you my ISA Sensor Dump on the 20/4/2024 and you get back saying Thank you! Everything seems to be fine there. I suppose your CPU fan was not shown in the list of the available sensor items because the CPU fan wasn't spinning at that time. so i send you this message saying Even if the CPU fan wasn't spinning, it should be shown in the list as the same way GPU Fans are shown even they remain at 0 RPM. I think, problem is somewhere else. Please suggest! but it has not Solve the issue Quote
Tony Lou Posted May 21, 2024 Author Posted May 21, 2024 sorry i bin away i do not no as i am all new to this as i built my PC a few months ago my set up my CASE: HYTE Y60 in white my MOTHERBOARD: MSI MPG X670E CARBON WIFI my FANS: Lian-Li UNI FAN AL120 V2 ARGB PWM Lüfter my RAM: CORSAIR DOMINATOR PLATINUM RGB DDR5 RAM 32GB x4 my CPU: AMD Ryzen 9 7950x my M.2: Samsung 990 PRO 2TB PCle 4.0 ( Up to 7450 MB/s)NVMe M.2 (2280) my Display Monitor: my CPU Cooler 360mm:ASUS ROG Ryujin III 360 with a 3.5” LCD Display, White my GRAPHICS CARD ASRock Radeon RX 7900 XTX Taichi OC 24GB Quote
Loyd Posted May 22, 2024 Posted May 22, 2024 you need to check your bios to make sure you have your fans running. read you manual on how to get into the bios ( press F2 or del is a lot of MOB) I cannot hold your hand you need to figure this out. the fans have to be seen in bios before they will work in the sensors. good luck Quote
Tony Lou Posted May 24, 2024 Author Posted May 24, 2024 I got it but I do not no why my bios is green? hope this help you for you to help me Quote
Loyd Posted May 24, 2024 Posted May 24, 2024 from what I can see you have the possibility of 6 fans, 1 pump, and a flow meter? that is some setup. anyway none of the fans are running or not connected. change the setting from auto to pwm and make sure your fans are plugged in correctly. all four pins in the correct holes. now you are going to ask how do I know that? the jack or pins on the mob ar 4 in a row with a little plastic guide off center on one of the longer sides. the plug (wire) has four holes and on one side also off center is a guide. these two guides go together. i will bet your fans run but do not vary in speed good luck again Quote
Tony Lou Posted May 24, 2024 Author Posted May 24, 2024 my fans are all connected if you look at the pic you will see? Quote
Loyd Posted May 24, 2024 Posted May 24, 2024 the use of the li fan controller negates any bios control and aida 64 reporting. that is why you have no fan speed reporting. by the way great setup. Quote
Awol Posted July 15, 2024 Posted July 15, 2024 Lian Li Uni fans will not show on Aida64 if they are powered via the Lian Li hub. I have the same issue as do loads of others. Quote
