Wally Nickvine Posted August 11, 2013 Share Posted August 11, 2013 Hello people, I recently bought a usb stick Kingston DT101 G2 16GB and I copied him AIDA64 Extreme Edition trial version to test it. When I open the program he normally open... close it, but then if you try to copy a file on the stick an icon appears and warns me that it is corrupt and need to format my USB stick. Apply a new formatting to the USB stick , going all right , copying and writing are within normal parameters all the files (music, move, games, .doc, .txt... etc) including when i copy to usb stick AIDA64 Extreme Edition trial version everything is okay. If open AIDA64 and and close it i get the same error from Windows 7 (x64) tells me that the files are corrupted and need to format the USB stick and lost everything on stick of course. I scanned the stick and has no error, really do not know who is solving. Thank you for understanding and hope to find a solution. Quote Link to comment Share on other sites More sharing options...
Fiery Posted August 11, 2013 Share Posted August 11, 2013 My only guess would be that the RAID and external drives scanning module of AIDA64 makes the stick's firmware go crazy for some reason. The solution would be to exclude the drive from the scanning. In order for us to add your drive to the exclusion list, we need to have its USB hardware ID. Please go to the Device Manager, find the drive in the list, right-click on it --> Properties --> Details --> Parent. The USB hardware ID should be in the format of "USB\VEN_xxxx&PID_yyyy". If you could send us the ID, we can add it to the exclusion list, and send you a new AIDA64 beta to try it on your system. Thanks, Fiery Quote Link to comment Share on other sites More sharing options...
Wally Nickvine Posted August 11, 2013 Author Share Posted August 11, 2013 First thanks for the reply, I followed the steps Device Manager, find the drive in the list, right-click on it --> Properties --> Details --> Parent but not found an ID like this USB\VEN_xxxx&PID_yyyy i foun this ID UMB\UMB\1&841921d&0&WpdBusEnumRoot I open AIDA from my computer and i checked the ID with AIDA and i found this: ID Hardware USBSTOR\DiskKingstonDataTraveler_2.01.00 Edit: I found this ID in C:\Windows\inf\setupapi.app.log USBSTOR#DISK&VEN_KINGSTON&PROD_DATATRAVELER_2.0&REV_1.00#08606E6D3FDEAD41D70D01F3&0# I also said I did several tests on PCs and laptops (not only to my PC), if you copy AIDA from stick to any PC or laptop , eject the stick and start the program it's ok, no errors. If you start the program from stick inserted to any PC or laptop and after i close it or when the stick is inserted... i get an error with corupted. Thank you for support. Quote Link to comment Share on other sites More sharing options...
Fiery Posted August 11, 2013 Share Posted August 11, 2013 In that case then I guess it would be better if you could create a TXT report of the Devices / USB Devices page of AIDA64, and copy-paste into this topic. We'll then find the ID in there I understand that the issue may not be directly in connection with the RAID member enumeration (due to the fact that you mentioned about stick behavior), but it may still be useful to exclude the stick from the RAID member enumeration. Maybe it helps, maybe not, but sticks shouldn't be scanned anyway for RAID members Quote Link to comment Share on other sites More sharing options...
Wally Nickvine Posted August 11, 2013 Author Share Posted August 11, 2013 --------[ USB Devices ]------------------------------------------------------------------------------------------------- [ Generic USB Hub ] Device Properties: Device Description Generic USB Hub Device ID 8087-0024 Device Class 09 / 00 (Hi-Speed Hub with single TT) Device Protocol 01 Supported USB Version 2.00 Current Speed High (USB 2.0) [ USB Mass Storage Device (DataTraveler 2.0) ] Device Properties: Device Description USB Mass Storage Device Device ID 0951-1665 Device Class 08 / 06 (Mass Storage) Device Protocol 50 Manufacturer Kingston Product DataTraveler 2.0 Serial Number 08606E6D3FDEAD41D70D01F3 Supported USB Version 2.00 Current Speed High (USB 2.0) [ Generic USB Hub ] Device Properties: Device Description Generic USB Hub Device ID 8087-0024 Device Class 09 / 00 (Hi-Speed Hub with single TT) Device Protocol 01 Supported USB Version 2.00 Current Speed High (USB 2.0) [ USB Input Device (PS/2+USB Mouse) ] Device Properties: Device Description USB Input Device Device ID 09DA-000A Device Class 03 / 01 (Human Interface Device) Device Protocol 02 Manufacturer A4Tech Product PS/2+USB Mouse Supported USB Version 1.10 Current Speed Low (USB 1.1) This is report Quote Link to comment Share on other sites More sharing options...
Wally Nickvine Posted August 13, 2013 Author Share Posted August 13, 2013 It seems that the problem was solved, I made a formatting low level and preventive I unchecked RAID member enumeration + RAID SMART support. Now I can open to stick AIDA64. Thanks for the reply and if it happens something will keep you posted. Quote Link to comment Share on other sites More sharing options...
Fiery Posted August 14, 2013 Share Posted August 14, 2013 Thank you for letting us know, I'm glad you managed to make it work. Quote Link to comment Share on other sites More sharing options...
