chiznitz Posted November 14, 2013 Posted November 14, 2013 I did a quick look through the forums and didn't see anyone ask this... Sometimes when I run the system stability test I notice the cpu usage goes from 100% to 0-2%, the window stays green and doesn't indicate a test has failed. I've had this happen when only FPU is checked and I also test using, FPU, Cache, Memory, and CPU and have seen the same thing happen. Is AIDA64 doing something with cache or memory at this time that does not utilize cpu 100%? I haven't watched it for more than 5-10minutes when its doing this so I'm not sure if it ever goes back up, just curious. Thanks Quote
Fiery Posted November 16, 2013 Posted November 16, 2013 It may happen when the stress test process crashes, without providing any feedback to the System Stability Test window. Is your computer overclocked or specially tuned? Quote
Keyz Posted November 26, 2013 Posted November 26, 2013 Hi, I've been having the same issue. After about 5-10 minutes of FPU testing the CPU usage drops down to ~20%. The CPU (4770K) is overclocked / over-volted. No other stability issues - Prime95 and non-FPU Aida tests work normally. Does this indicate an issues with stability or the software? Quote
Fiery Posted November 26, 2013 Posted November 26, 2013 Please try it at stock settings, without any overclocking. If it works fine that way, then your system is unstable when you have it overclocked Quote
