One of the System fan header was not detected by AIDA64 (Lian Li UNI Fan SL120)
I use a Gigabyte Z790 AORUS ELITE AX (rev. 1.x) motherboard and a 'Lian Li Galahad CPU AIO 360 UNI Fan SL120'.
AIDA64 can detect the Lian Li CPU AIO fans but cannot detect a Lian Li Uni Fan AL120. All the fans can read from the bios and Gigabyte Control Center and all fans used 4 pins. I have tried using a different brand of fan on system fan header 3 and it can be read by AIDA64. Does that mean that AIDA64 is unable to support Lian Li Uni Fan AL120?
Currently, I'm using system fan header 1 for my rear exhaust fan, fan header 2 for the bottom fan, and fan header 3 for the front fans which is the Lian Li Uni Fan AL120.
I have attached my ISA sensor dump text file for you to study it.
I hope there is a fix for this. Thanks.
ISA_sensor_dump.txt
AIDA64 currently doesn't support Lian Li fans.
  • Fiery changed the title to One of the System fan header was not detected by AIDA64 (Lian Li UNI Fan SL120)
Posted (edited)
I finally got my AIDA64 sensor to detect my Lian Li UNI daisy chain Fan SL120 fan speed. I connected the Lian Li UNI daisy chain Fan SL120 to my Gigabyte Z790 AORUS ELITE AX (rev. 1.x) motherboard 'SYS_FAN4_PUMP header' or the CPU pump/CPU OPT. It seems AIDA64 cannot detect this daisy chain fan on a normal sys_fan header. It's the same problem for my NZXT F360 RGB Core - 360mm Single-Frame Fan Unit. AIDA64 can detect a single Lian LI SL120 fan on a normal system fan header. Now AIDA64 can read all my fans😄.
Edited by BHSY
