You cannot be added to change the fonts panel OSD? For example change the size of fonts. Often OSD on the floor of the screen, I would like to reduce the font size.
translate yandex:)
Go to AIDA64 / main menu / File / Preferences / Hardware Monitoring / OSD / OSD Items, select any of the items (or multiple items using Ctrl key), and press the Configure button.  You can change label, font name, font size and font style of any OSD item that way.
