Luis Gabriel Gerena Posted December 15, 2024 Posted December 15, 2024 Hello, I am trying to setup my AIDA64 panel again. I used to run it on a Samsung Tablet S10.5 via SuperDisplay app for wireless display (IIRC) but I was wondering if you can recommend a display that is easy to setup with AID64. The one thing I love about the Tablet was the OLED display but I am sure those cool slim displays are all IPS so that would have to do. Any models you can recommend that work great and easy to configure with more compatibility with themes will be appreciated Thanks! Quote
Fiery Posted December 16, 2024 Posted December 16, 2024 On 12/15/2024 at 2:27 AM, Luis Gabriel Gerena said: Hello, I am trying to setup my AIDA64 panel again. I used to run it on a Samsung Tablet S10.5 via SuperDisplay app for wireless display (IIRC) but I was wondering if you can recommend a display that is easy to setup with AID64. The one thing I love about the Tablet was the OLED display but I am sure those cool slim displays are all IPS so that would have to do. Any models you can recommend that work great and easy to configure with more compatibility with themes will be appreciated Thanks! Any display would work as long as it is connected to your PC as a monitor, via e.g. HDMI or DisplayPort interface. Then you can use the SensorPanel module of AIDA64. Quote
