Fyew-jit-tiv Posted January 4, 2011 Posted January 4, 2011 Hi Aida, Simple request really. Could you guys please and an export/import feature to the LCD items panel thus allowing a user you backup info designed on an external LCD. Thanks. Fugitive Quote
Fiery Posted January 4, 2011 Posted January 4, 2011 You can backup and restore the AIDA64.INI file for that purpose. It holds all the Preferences settings, and it includes no personal data or other sensitive info. Regards, Fiery Quote
Fyew-jit-tiv Posted January 4, 2011 Author Posted January 4, 2011 Hi Fiery, I did discover that from a user in another thread. I just think it would be good if we had an option to export/import a .csv file type Which would give us the chance to change layouts on the LCD at will, Also backup and share LCD setups with other Adia64 Users. Just a thought! Thanks Quote
