AIDA64 7.40.7100 makes my Corsair fan RGB animation stutter
Go to solution Solved by Luis Gabriel Gerena,
Hello!
So I finally got my Samsung Tablet running to display AIDA64 themes to keep an eye on mainly CPU, RAM and GPU Temps.
I use SignalRGB to control all the RGB in my system and its fantastic.
The only issue is that when I use AIDA64 it makes the animation stutter for the Corsair Fans. The only thing I didnt notice stuttering was the Corsair RGB RAM.
I can adjust the frequency of the stutters by increasing the Update Frequency for Sensor Panel but then at that point I am getting much slower updates of the temps.
Any ideas of why this happens and workaround?
9 hours ago, Luis Gabriel Gerena said:
Hello!
That seems like an issue with Corsair's own software framework (iCUE).
11 hours ago, Luis Gabriel Gerena said:
Unchecking this option fixed it for me
Then it means that polling your Corsair PSU somehow interferes with the Corsair fans.  I have no idea how could that happen though, since they use different interfaces to connect to the system.  Or maybe your fans are connected to or integrated into the PSU?
