Ok, I have a two monitor setup and the sensor panel as the third.
two main monitors are plugged in via dp on the gpu.  The sensor panel is on the motherboard.
It works fine but most of the time when  boot up the computer it will be on the main display.  I open up aida64 preferences and it is actually listed to be on the sensor panel monitor.  So i have to click on which ever monitor and then back in to the monitor i want it in.
Is there a way to fix this at all?  just seems a little bothersome
Please try the following:
1) Upgrade to the latest AIDA64 beta update:
2) When the issue of the SensorPanel appearing on the wrong monitor occurs, in AIDA64 please press Ctrl+D --> System Debug --> Devices Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post.
  • Fiery changed the title to SensorPanel starting up where ever it likes!
  • 4 months later...
We've just rolled out the first beta build of the next-generation AIDA64 that fixes -- among many other things -- several issues related to how AIDA64 handles multiple monitors:
