barrie17 Posted January 4, 2011 Posted January 4, 2011 Hi Everyone! I'm a newbie to this software and to the forum so I hope that this hasn't already been posted (couldn't find any posts) I purchased a full version of the software because the "Trial Version" didn't display Voltage or Fan data and I assumed that these values would be unlocked by the key. It appears as though the Aspire motherboard ACPI data doesn't support the function or the program has a deficiency.It would be great if anyone could shed some light on this problem. The laptop bios is the latest V 1.33 Phoenix offering for the Aspire 5520 OS - Windows7 Home Premium 32bit CPU is an AMD TL-58 which I will be upgrading to a TL-66 as soon as it arrives. Thanks, Barrie Quote
Fiery Posted January 4, 2011 Posted January 4, 2011 Most notebooks are not equipped with a full-blown sensor chip like desktop motherboards, hence measuring voltages and fan speeds (RPM) are not possible on most notebooks. This is a lack of hardware implementation, and not a software deficiency. I hope you find other useful features in AIDA64 that would justify the purchase Regards, Fiery Quote
barrie17 Posted January 4, 2011 Author Posted January 4, 2011 Most notebooks are not equipped with a full-blown sensor chip like desktop motherboards, hence measuring voltages and fan speeds (RPM) are not possible on most notebooks. This is a lack of hardware implementation, and not a software deficiency. I hope you find other useful features in AIDA64 that would justify the purchase Regards, Fiery Thanks for the information. I kind of thought that might be the case. I'm still happy with the program and it will be more useful on my tower. Cheers, Barrie Quote
