Novax1 Posted January 16, 2014 Posted January 16, 2014 Hello happy new year AIDA64 LCDhost screen display and G19 Testing master volume update data is incorrect when moving volume takes about 2 or 3 seconds to update. I have set to 500 ms in preferences and refresh show an image http://i58.servimg.com/u/f58/17/28/04/23/aida6410.png 1 Quote
Fiery Posted January 17, 2014 Posted January 17, 2014 It's normal. To make sure the hardware monitor module of AIDA64 doesn't consume too much CPU cycles at each update, some items are updated at a minimum of 2, 3 or 5 seconds update rate. Quote
Novax1 Posted January 18, 2014 Author Posted January 18, 2014 It's normal. To make sure the hardware monitor module of AIDA64 doesn't consume too much CPU cycles at each update, some items are updated at a minimum of 2, 3 or 5 seconds update rate. Thanks for answering but then for serves to update the values ​​I have in to 500 ms in preferences and refresh (ms)?? regards Quote
Fiery Posted January 20, 2014 Posted January 20, 2014 Thanks for answering but then for serves to update the values ​​I have in to 500 ms in preferences and refresh (ms)?? regards I'm not sure what you mean there. Basically, the global update frequency controls the update rate for most sensor items. And there are exceptions from that rule, like the Master Volume, which is never updated more frequently than once per 3 seconds. Quote
Novax1 Posted January 20, 2014 Author Posted January 20, 2014 I'm not sure what you mean there. Basically, the global update frequency controls the update rate for most sensor items. And there are exceptions from that rule, like the Master Volume, which is never updated more frequently than once per 3 seconds. Thank you again. I feel bad explanation but I have to translate Spanish to English but it's a shame I show the information in Lcdhost AIDA64, To Elcontrol audio. and I hate what it takes to upgrade. thank you very much. Quote
